Entire day of rain - storm so lots of rain .
15:30 - finally get a drop through . You can see it’s been building up to that . I’m going to leave this as is until spring . But if I were to seal the concrete I.e to prevent water coming through what would I use? . I guess I should be happy as gone from half a bucket to just this .
2 hours ago, Pocster said:
Entire day of rain
I turned my wipers on at 4:55, and turned them off at 18:02, 617 miles in the (expletive deleted)ing rain, which was at its worst around Bristol. Avonmouth bridge was well soggy.
Avonmouth is a shit hole
I would clean that up with a bleach solution and scrubbing brush then apply shower tanking paint and see what happens.
Hairline cracks in the concrete also I want to fill . Did assume some concrete / brick sealer waterproofing was the thing to try .
So a small number of drops did get the floor . Didn’t put a bucket to collect . But it is a small amount . Just checked it now - whilst not dry it’s clearly drying out . Considering how much rain we had and how quick it’s drying does kind of confirm it certainly isn’t a lot of water .
Chat suggests . Clean it all up . Ct1 the joints I.e block work on the concrete - water gets through the mortar at this point . Then ka slurry the lot .
Edited by Pocster
I had a similar but larger problem when trying to control the water leaks on my firepond
 there was pressure as well with my leaks in the 5 meter wall behind the pond and a constant flow
 it was a sika _plugging fast setting cement
mix it up  and you got  5mins to get it on -so small areas at a time
and can be use under water if you press it hard  onto the leak
took me 2 days frigging about to gat all the leaks plugged   but it worked
mix it up till its like sloppy putty --then GO
I even used it on my water course --old water supply made from stones just laid on each other
problem was it was leaking too much from the stone culvert and coming outanywhere it like where it went through the wall and not where I wanted it contained in the stone work
 imagine a stone culvert coming to a dry stone dyke and trying to get all going where you wanted  on the other side --then you will get the picture
did not matter with original set up as all the leaks ended up in the open collector at other side of wall , but as i was piping it in 300m twin wall all the way down to firepond
8mm drop and 20m downhill  to where it meets the wall above the firepond
I did not want it to form another stream under the piping  and end up with the wall collapsing as it had done in the past   - not a problem then as it made its way into the stone culvert which heads off across my courtyard and down the 95m drop into the quarry
 that stone culvert I replaced with more 300mm twin wall
 problem sloved but alot of frigging about
I would not use CT! --just use the wate plugging cement
even on damp surfaces
Chat has now changed its mind 🙄 . Won’t bother with ct1 . Simply tanking slurry over the lot . There are no gaps it’s just porous material.
47 minutes ago, Onoff said:
Moisture resistant plasterboard is GREEN!
Why do I want moisture resistant plasterboard ?
On 10/11/2025 at 16:13, Pocster said:
... . Paranoia causes me to check the room with the leak a few times everyday…. 🤪
Every single non-professional self builder is somewhere on the  paranoid scale.
Don't care what they might say in public .... Some hide their problem well, others not. I don't.
It's wet innit. Small wet patch in our hallway.  I see it and immediately look up at the ceiling above the wet patch.
SWMBO looks at me more in sorrow than anything and says...
"Our puppy can't pee from up there can she ... ya dickhead.... "
  • Haha 2
54 minutes ago, Andehh said:
Been in for 2.5 years, every heavy rain has me walking around staring at the ceilings.... 🙃
Glad it’s not just me . But checking 10 times a day when raining probably means I need counselling . Storm tomorrow- torch ready !!
Good to know that we're both fekkin' eejits.
Debbie always ( and gently ) says ....
"Nothing to be done about it tonight even if there was a leak"
It's all the fault of that cracked tile we had  years ago, let in a drop or two.
Of to the quack tomorra to get treatment for my PTSD.
