ProDave Posted January 20 Posted January 20 Out in the garden today, I noticed there was no noise from the treatment plant, the Charles Austen ET100 has failed again. I have once replaced the diaphragms in this pump, I don't recall exactly when and I can't find my previous post about it, but it does now seem very long ago that I replaced them. (if anyone can find my previous post please post a link to it) So the question is, do I replace them again? And accept this is a design of pump with an inbuilt short design life of the diaphragms? Or are there alternatives available that are better, more reliable and possibly lower power? I know these are generally talked of as good pumps, but to me something that needs servicing so frequently does not seem a good design. How about this: https://www.ebay.co.uk/itm/315879624105?_skw=100l%2Fm+piston+air+pump&itmmeta=01JJ2C6CWW195RC06F730H2JT0&hash=item498be48da9:g:dOUAAOSwa2VnEMrs&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKm21zAzCS4zNd2jnxfrrOBkOhQYhAk7CosWXuQypC5wJb6PfvsNVkMOBejzWhXwVDjHUnawcrurG%2FiIsbWdtpK%2Fn8IwRJZJP8M7oQQgPTxjf%2BRiq7GH1iDIoBnPZGgGTwO4j0vTT7Wimo9wYGyM0IRgNX79VT%2B0F5RTNeR24E6dCJ86hGQoWhtrDsRU4%2BExDuMp6nvrHeqB6iyjGykP7uwnOH4F0eSd%2BtG3ikLuqrSuKWOLLWQVKQ1ID679iWiY4E4eWE5W00urRUrvWQ%2FZacju8p3mCAHzPjJTq1hBl4CtUw%3D%3D|tkp%3ABFBMzs6ZzJBl An 82L/min piston air pump that consumes 60W of power for £46.99 To put that into perspective the ET100 diaphragm pump is 100L/min and the service kit alone costs £40 each time it goes wrong and it consumes 105W of power.
ProDave Posted January 20 Author Posted January 20 No thought from anyone? My choices seem to be spend £40 to replace the diaphragms in the ET100. Yes that will get it working again. BUT you have to buy a kit that also contains a new armature (2 magnets moulded into a plastic armature) I am not convinced that needs replacing and I have not found anywhere to buy just the diaphragms. And as for being forced to buy unnecessary parts, there is also 2 sets of flap valves in this pump that do not get replaced with this service kit. The larger Charles Austen pumps do replace the flap valves as part of the service kit. So one has to question how many times can you service this pump with this kit before the flap valves give up? OR I can spend £44.99 to buy a completely different but new pump. It will all be new. It may be better and last longer, it may not. But if the "service" cost when it needs it is only £5 more to get a completely new pump next time, it has to be worth a try? Is there nobody reading this that has tried alternative pumps and can post their findings, in particular how long they last and can they be serviced or do they need replacing compete?
Jeremy Harris Posted January 20 Posted January 20 I don't know if our experience with blower pumps is typical or not, but we are still using our ten year old Secoh JDK pump with no failures so far. I ignored the servicing instructions (out of laziness) and just bought a spare pump plus a couple of sets of spare diaphragms, so if the pump failed I could just quickly swap in the spare and replace the diaphragms in the old one in slow time. I ran out of bottle after 7 years of non-stop operation and changed the diaphragms as I was sure they must be about to fail. It didn't need this at all, as the old ones looked just fine. The pump's been running for about three years on the new diaphragms and shows no sign of giving up. The only thing I do annually is take the top cover off and give the air filter a clean, as it tends to collect a lot of dust and dead bugs. Other than that it's just quietly got on with doing its job.
JohnMo Posted January 21 Posted January 21 9 hours ago, Jeremy Harris said: Secoh JDK pump We are using the same, our first one failed after 2 years, but it was operating in a near sand pit, so no surprise really. But they are pretty cheap to get new and all parts are available to repair.
ProDave Posted January 21 Author Posted January 21 Thanks for the recommendations for the Secoh. The cheapest I have found for that is £160. That's still a hard sell when I can get the Chinese piston pump for £45. It would have to last 3 times as long before needing a service.
Gone West Posted January 21 Posted January 21 13 hours ago, Jeremy Harris said: but we are still using our ten year old Secoh JDK pump with no failures so far Our Secoh pump lasted eleven years before we replaced it, with another updated Secoh pump, which was more economical to run. I did use to turn the filter through 90 degrees half yearly and replace it annually. I also replaced the diaphragms every three years, just to be sure.
crooksey Posted January 21 Posted January 21 In theory a diaphragm should be replaced every 2-3 years. If your plant was under a service plan, this is the interval it would be changed at. I order the repair kits from ALI express and keep two in stock. £30 every 2 years isn't a huge expense.
ProDave Posted January 21 Author Posted January 21 Well I have made a decision and ordered the £45 piston pump. It's advantage should be longer life than a diaphragm pump. but I expect it will be noisier. In preparation for that I am going to cut a board to sit in the pump chamber to sit on some foam. The default pump chamber in the conder TP is just like a plastic bucket with the pump sitting on what is doing a good job as a drum skin. You could not design a housing to me more noisy if you tried. The same make of pump as the one I have bought also do these diaphragm pumps that look remarkably similar to the Charles Austen type. But for those the spares are available individually including the air chambers and the flap valves contained in them, so if I did go back to another diaphragm pump, that would be a good argument for choosing one of those. It really annoys me that the spares are not available other than in a kit, for the ET100
Gone West Posted January 21 Posted January 21 This thread has just reminded me that I bought a Secoh full service kit, for the old EL series pump, about six years ago. The part number is K-EL-60/80/100/120W/150W/200W. It moved house with me and it's been sitting around in the house for too long. It it's of any use to anyone I'll send it to them if they donate a tenner to Buildhub. Just let me know. 1
ProDave Posted January 21 Author Posted January 21 The other thing i did today as well as preparing a better base in the pump chamber, was I contrived a long hose from my immovable air compressor in the garage, to the treatment plant, just to blow some air down the pipe to ensure it was not blocked, and it ran free and you could hear the bubbles blowing in the "contents"
Jeremy Harris Posted January 21 Posted January 21 9 minutes ago, ProDave said: The other thing i did today as well as preparing a better base in the pump chamber, was I contrived a long hose from my immovable air compressor in the garage, to the treatment plant, just to blow some air down the pipe to ensure it was not blocked, and it ran free and you could hear the bubbles blowing in the "contents" I built a remote box to house the air pump and alarm, because I wasn't wholly happy with having it sat in a box dangling over the main chamber of the unit (we have a BioPure). The main advantage of doing this was that, with the box being by the side of the drive I'm much more inclined to lift the lid and check the pump and alarm:
SteamyTea Posted January 21 Posted January 21 1 hour ago, Jeremy Harris said: with the box being by the side of the drive I did not even notice it when I parked right next to it.
ProDave Posted January 24 Author Posted January 24 My cheap pump arrived today. I didn't think I was going to get a chance to try it as it was raining hard and playing with an electric pump in a pit in the rain was not high on my list. But the rain stopped and the sun even came out so I could not resist having a go. Initial thoughts, this pump is VERY noisy when not doing any work, but once connected to a "load" it quietens down a lot. It is now pumping and blowing bubbles through my tank as it should. Still some tweaking to do, it's outlet connector is slightly smaller so the quick bodge with a bit of tape needs improving, and there is still work to do with soundproofing but with the lid on the pump chamber it is not so bad, but still as predicted more noisy than the ET100. I will leave that until a better day as the rain was just coming back as I finished and the wind picking up.
ProDave Posted January 25 Author Posted January 25 I have been out again today in a lull in the wind and rain, experimenting how to mount the pump. The bit of wood on foam did not make the pump much quieter, so I then started to think what have I got to hand that I can try. Simple solution, I have just laid a standard 4" concrete block in the bottom of the pump chamber and stood the pump on that. It is VERY much quieter like that and with the lid on, hardly any noisier than the ET100 pump was. So I will leave it mounted like that. It was also another test, having been running for 24 hours now i wanted to see how hot the pump runs, and it is barely warm to the touch. And still blowing bubbles nicely in the soup. So now begins the long term test to see if this piston pump lasts any longer than the ET100 diaphragm pump.
