Which robust blocks to use to achieve U-value 0.18 as part of CWI on extension?
ab12
Hi All
Having a rear single storey extension built and need to achieve U value of 0.18 for CWI.
Build up will be brick, followed by 150mm DriTherm 32 slabs, then blocks and then ideally wet plaster on blocks internal face although architect has specifies dot an dab to the blocks.
Have been eyeing the following blocks:
Plasmor Fibolite 7.3N (U value 0.28) and Plasmore Fibolite 3.4N (U value 0.24)- both of these are lighweight aggregate blocks.
Alternative options include Thermalite Hi strength 7.3N (u value 0.19) which is Hi Strength aircrete and Thermalite Shield 3.6N (U value 0.15) which is Standard aircrete
Looking for a block which is sturdy and robust not going to crumble and fail when drilled into as the rear storey extension will house a kitchen with lots of wall fixings.
From the above options which blocks would you recommend which would satisfy both achieved combined u value of 0.18 and is robust.
Thank you
To my mind you are hoping you get a good brickie that can execute all this properly..and for that you will need to pay for a professional brickie @Canski may be able to give you some realistic rates. To be frank you'll need to stand over them all day long as fitting insulation properly into a masonry cavity is like buying a second hand car! Give it a miss unless you have the time! Fitting the any kitchen units for example is the least of your worries.
A safer bet is to go for a TF which you can inspect, the air tightness and so on.
Mind you if you have the capability to build this yourself then go for it. The big secret is to take care of your aerated blocks and condition them on site.
  • Like 2
A dense concrete block will be fine
Most Architects specify dot and dab It does have a warmer fell if sealed properly
Using an insulated plasterboard for dot and dab on the perimeter walls will up rate your U values and give you a very warm build
Timber Frame is a very good option
But expect to add about a third to your build cost
We're using the Fibolite 7n. When handling they're much more robust, feel more like a dense block than the thermalite 7, but still a decent weight and u value. Temporary timbers have held with frame fixers into the blocks very well.
  • Like 2
I’ve laid a few dozen thousand Fibolite blocks as these are a preferred block for one of my developer customers. They are a good block and if you can get the required u values using them then go for it.
Ytong blocks were my preferred option for my build though. A good solid aerated block that can be cut easily and nice and square using an old blade in a battery powered circular saw.
Dritherm 32 is my preferred insualtion as well. Easy to cut neatly and doesn’t over expand when you get it out of the pack like some other makes.  I used it on my build with my methods posted on a previous full fill cavity hater thread. Just make sure to keep it dry.
Edited by Canski
Added comments regarding dritherm 32
Hi Canski
Following your comments: ''my methods posted on a previous full fill cavity hater thread. Just make sure to keep it dry.'' I have been searching for the thread but cant seem to find it.
Can anyone post a link please.
Follow on question you mention about keeping the insulation dry, can you please expand on this- is that whilst it is being installed and overnight when it is in the exposed wall cavity ?
Thanks
Our expanded even more when wet! When in the cavity didn't seem an issue, but if outside it made it impossible to fit between the blocks.
Caught the brickies tearing it in half as they got to the top, to save climbing down for more, so ended up daily inspecting to ensure they didn't! As I didn't trust the sods.
