On 19/01/2025 at 15:24, Jamo73 said:
Thanks nick. Was hoping the fence wouldn’t be needed when the wall was built as it’s so close to the boundary. Our real concern is we want this house to be a forever home and the higher the wall gets the worse the workmanship and I can’t see it lasting the test of time. This will no doubt become our issue after the neighbour has gone and it needs replacing in the future as over half this wall is alongside our house and is not accessible to carry out repairs from either side!
If you’re on talking terms then just pay to have it rendered and lose the fence? There is not a cats chance that the wall is getting re-made or much further improved, let’s be honest…. :/ You’ll use a lot of energy and life force fighting against this, so just look at whether you want top pay for a new fence (eventually, regardless, as that’s a waffle fence and will snuff it) or use that investment to make the wall look as you wish?
58 minutes ago, Canski said:
below par Bulgarian
But Spanish renderers and tilers are superb, and that would end up looking good....but they don't have our weather in areas where they do it like this..
RE the original question, that wall will get weeds growing from the open joints so I think it could cause problems all round.
  • 1 year later...
Forgot to put an update on this!!! It FAILED spectacularly. Building control refused to sign it off on many counts which was the only sensible outcome. P.S. for those who thought it was acceptable and those that are watching and still build like this, don’t come to Shropshire , substandard workmanship isn’t acceptable here 😎. For those that were helpful and constructive I thank you 🤠
  • Like 4
Thank you for posting with the outcome. :)
That is only PART of the outcome.
What happened next?  Was it left but without BC signoff (would only be a problem if they sell) or did BC insist on remedial work?
Presumably you do have a Party Wall Agreement in place ?
And you have ensured that the eaves and gutter will not project onto your land (which is illegal) and this is clearly defined in the drawings within your PWA.
Presumably there are no windows in that wall and overlooking your property ? Nor vents or external pipes ?
Edited by Spinny
Yes Spinny, that is all in place and nothing overhanging or over looking windows. Pro Dave, the owners are in their late 80’s and we think that at the moment they are just going to leave it!!! The issue then I suppose will pass to the next owners but it will be un unmortgageable so will potentially massively reduce its sale value…… might but it myself should this be the case 😂
