Pocster Posted January 11 Author Posted January 11 This looks good ! Could live with black at this price !
Russell griffiths Posted January 11 Posted January 11 Get some white air conditioner outdoor trunking, it’s the stuf they use to put air on pipes inside, lag that shit pipe you installed and put it inside a nice neat white trunking, it comes with nice radius bends and all sorts of stuff. f##rk me got you out of trouble again 😘 1
Pocster Posted January 11 Author Posted January 11 15 minutes ago, Russell griffiths said: Get some white air conditioner outdoor trunking, it’s the stuf they use to put air on pipes inside, lag that shit pipe you installed and put it inside a nice neat white trunking, it comes with nice radius bends and all sorts of stuff. f##rk me got you out of trouble again 😘 You’s me bitch for sure bro
Pocster Posted January 11 Author Posted January 11 This packed with insulation ? kind of what I said ; pipe within insulated pipe
Russell griffiths Posted January 11 Posted January 11 FFS NO, NO ,NO ,NO. I TOLD YOU WHAT TO USE, WHY DO YOU WANT TO USE SOME GASH DOWN PIPE. 1
Pocster Posted January 11 Author Posted January 11 24 minutes ago, Russell griffiths said: FFS NO, NO ,NO ,NO. I TOLD YOU WHAT TO USE, WHY DO YOU WANT TO USE SOME GASH DOWN PIPE. I couldn’t find any at a sensible price . What’s wrong with down pipe ?
Pocster Posted January 11 Author Posted January 11 3 minutes ago, Russell griffiths said: That’s better. carry on sir. Yes boss ! I’ll order that and some conventional insulation for the 21mm. Yous still me bitch
TerryE Posted January 14 Posted January 14 On 11/01/2025 at 14:41, Pocster said: Yeah - somehow I knew this was safest route . Boxed in how / with what ? - not keen on timber . Some form of plastic ? TBH the internals should be dry and well drained, so personally I'd just do it in timber, e.g a length to wood decking or other preserved wood from Wickes or equiv. You cam pick up a length of 25×120 mm decking for about £8 and cut to form a U profile cover with a nice sloping lid. Easy to fix to the wall. Maybe not the most beautiful, but it will do the job and stop your drain blocking. And yes, in 10 years time you might need to replace it. 😅
Onoff Posted January 14 Posted January 14 I'll raise you square guttering with 3D printed end cap etc.
Pocster Posted January 14 Author Posted January 14 28 minutes ago, Onoff said: I'll raise you square guttering with 3D printed end cap etc. Abs ok in weather ? Temperature range I mean . Not going to split / crack / fade ??
Onoff Posted January 14 Posted January 14 6 minutes ago, Pocster said: Abs ok in weather ? Temperature range I mean . Not going to split / crack / fade ?? I would print in ASA. The X1C will handle it without issue. ASA has something like ten times the UV resistance of ABS.
Pocster Posted January 14 Author Posted January 14 Just now, Onoff said: I would print in ASA. The X1C will handle it without issue. ASA has something like ten times the UV resistance of ABS. Don’t think mine will do asa . I’s a poor fella now
Onoff Posted January 14 Posted January 14 2 hours ago, Pocster said: Don’t think mine will do asa . I’s a poor fella now Yes it will. We do ASA here no problem on the Bambu X1C:
Pocster Posted January 20 Author Posted January 20 (edited) All done like a “ checkatrade” pro ! Might foam the end around the pipe for peace of find Edited January 20 by Pocster
Pocster Posted January 20 Author Posted January 20 Just now, Russell griffiths said: Your a bloody legend mate. I know
