PSC88 Posted January 10 Share Posted January 10 Hi we have full planning approved. we have made some amendments to our second floor habitable loft. Namely making better use of the loft space and creating another room from the wasted eaves space. i have also added a skylight to this room which will only be visible from a Birds Eye view and not ground level, this was previous going to be a flat area of the roof. these drawings are the ones we are moving forward with for building regs. Do I need to resubmit plans or ask for non material amendments? my architect states as the changes are mainly internal (bar the roof light not visible from ground) that we need to do nothing. i just want to make sure I don’t have any issues with building regs/council building warranty etc going forward Link to comment Share on other sites More sharing options...
Russell griffiths Posted January 10 Share Posted January 10 As far as planning is concerned do nothing. with regards building regs you need to ensure this new area complies with everything, fire escape, etc etc. building inspector will not care you have moved a wall or divided a space, as long as it all complies with the regs. you will never see planning again unless you get a complaint about something from a nosey neighbour. Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 10 Share Posted January 10 45 minutes ago, PSC88 said: ... i have also added a skylight to this room which will only be visible from a Birds Eye view and not ground level, this was previous going to be a flat area of the roof. ... You can train almost any corvid or columba to carry messages. As yet there are no reports of trained, literate crows or pigeons who report to LPA Planners. .... Yet. (Well there might be in Hampsted or Sand Banks.) 1 Link to comment Share on other sites More sharing options...
Redbeard Posted January 10 Share Posted January 10 Is this a new-build or a refurb? Either way it may be permissible under Permitted Development. Have your PD rights been extinguished? Link to comment Share on other sites More sharing options...
PSC88 Posted January 10 Author Share Posted January 10 Thanks, not under permitted development as in conservation area so all removed Link to comment Share on other sites More sharing options...
Alan Ambrose Posted January 10 Share Posted January 10 I think I’ve seen reports ‘ere on the ‘ub of BC requiring fairly minor internal changes to be run by the planners. If I remember, a change of position of a hot water cylinder (?). Does that sound correct? Link to comment Share on other sites More sharing options...
SBMS Posted January 10 Share Posted January 10 9 minutes ago, Alan Ambrose said: I think I’ve seen reports ‘ere on the ‘ub of BC requiring fairly minor internal changes to be run by the planners. If I remember, a change of position of a hot water cylinder (?). Does that sound correct? BC might have requested calculations that the floor can take the loading of a full UVC if it is a first or second floor for example. Apart from that can’t see why BC would care where a cylinder goes. Link to comment Share on other sites More sharing options...
SBMS Posted January 10 Share Posted January 10 11 hours ago, PSC88 said: Hi we have full planning approved. we have made some amendments to our second floor habitable loft. Namely making better use of the loft space and creating another room from the wasted eaves space. i have also added a skylight to this room which will only be visible from a Birds Eye view and not ground level, this was previous going to be a flat area of the roof. these drawings are the ones we are moving forward with for building regs. Do I need to resubmit plans or ask for non material amendments? my architect states as the changes are mainly internal (bar the roof light not visible from ground) that we need to do nothing. i just want to make sure I don’t have any issues with building regs/council building warranty etc going forward I wouldn’t worry about planning. Just make sure building control are aware. Doubt your warranty will even be aware of any changes, your warranty inspector won’t have looked that hard at your original plans - ours certainly didn’t. Link to comment Share on other sites More sharing options...
Jilly Posted January 10 Share Posted January 10 21 minutes ago, PSC88 said: Thanks, not under permitted development as in conservation area so all removed Be careful in that case, it can be a palaver to change things without another planning application. Also, I’m fairly sure, if your drawings for planning and Building Control don’t align, you can’t claim the VAT back. Link to comment Share on other sites More sharing options...
Alan Ambrose Posted January 10 Share Posted January 10 I would think a simple non-material amendment at worst. Link to comment Share on other sites More sharing options...
