sb1202 Posted December 20, 2024 Posted December 20, 2024 Apologies if this is a daft question but I can't find an answer in any tech sheets or on here. I'm looking to order 100mm steico flex 1190 x 375mm WF insulation and fit it into new stud walls. The stud walls are standard CLS at 38x89mm and will be built to 400 centres, so I'm presuming the 375mm insulation will give a nice tight fit and I can work out for the long side with dwangs. My question is about the depth. Does this insulation compress into the depth of a 89mm stud against a membrane or do I need to pack out the joists with strips to get to the 100mm? (I couldn't get 95mm cls anywhere and 120mm/140mm deep studs are too deep for my application) Cheers
Canski Posted December 20, 2024 Posted December 20, 2024 Years ago I made the mistake of putting 100 mm rock wool into a 4x2 stud wall. Bear in mind the 4x2 comes out at 97 x 47mm. We squeezed it in and fixed the plasterboard only for the fixings to pop. 1
Conor Posted December 20, 2024 Posted December 20, 2024 Are these external stud walls, and therefore is this your main insulation layer? Or, are these internal partition walls? If the former, then you'll need to batten out using 22 or 25mm battens. If you compress the insulation, you reduce it's performance. If these are internal partition walls, use 50mm acoustic insulation instead. How are you running services?
sb1202 Posted December 20, 2024 Author Posted December 20, 2024 3 hours ago, Conor said: Are these external stud walls, and therefore is this your main insulation layer? Yes 3 hours ago, Conor said: you'll need to batten out using 22 or 25mm battens Not sure what you mean by this. Do you mean to pin a 25mm batten on to the short face of the stud? I can easily rip a 10mm strip for this. 3 hours ago, Conor said: How are you running services? Electrical only, through the insulation and sealed over the VCL with tape. This is a renovation so I can't afford reduce the room space with a service layer.
Russell griffiths Posted December 21, 2024 Posted December 21, 2024 (edited) I’ve only had this product in my hands for a few minutes, and it felt very firm. the stuff I messed with might not have been the flex version, have they made one more squishy for this sort of application. my opinion would be that it won’t compress down to 89mm. that’s a very expensive insulation option, have you looked at other methods. Edited December 21, 2024 by Russell griffiths
sgt_woulds Posted January 17, 2025 Posted January 17, 2025 Natural insulations will always cost more in the UK as it is such a small market and buyers have to absorb the increased costs of production, shipping and Brexit red tape. Unlike many countries in the EU, there are no local political forces to drive wider adoption. In most of Europe, there is price parity due to the scale of sales; in France and Italy for instance it is very hard to specify unnatural insulations due to building regulations. In the UK, the best we can say is that prices are on par with mineral wools and have better availability - rockwool costs a bomb to manufacture as it requires huge amounts of heat, and recently it needs to be ordered weeks in advance to ensure supply. There are many advantages to natural breathable insulations, especially for internal insulation. Regarding the OP's specific question, Steico should be cut roughly 5-10mm oversize between the battens. I wouldn't compress the surface more than 3-5mm behind plasterboard - any more than this and you will get bowing. 400 centres on your battens should work well, but I'd add 10mm strips to the face as you suggest. Installation info can be found here: STEICOflex_handling_instructions_en.pdf It is important to note that STEICO does not generally recommend achieving high U-values with IWI due to the condensation risk to the structure. There is, generally, a sweet spot between 40-100mm of woodfibre that balances the energy savings, cost, and condensation risk. If it’s of interest, their Technical Director took part in a webinar that covers some of these points: Rethinking IWI with Natural Fibre Insulation Useful advice can also be found in the following links: Insulation and retrofit - Finding the sweet spot - The Alliance for Sustainable Building Products (asbp.org.uk) The-use-of-natural-insulation-materials-in-retrofit.pdf (stbauk.org) If used behind plasterboard, you will need a moisture vapour variable membrane, (e.g. STEICOmulti renova or SIGA Majrex® or PRO CLIMA intello plus). These ‘smart’ membranes will limit the amount of water vapour entering the fabric but still allow the wall to ‘breathe’ during warmer periods. Correct installation of the membrane, and sealing connections to all surrounding elements is the critical factor with this approach. The best advice is to have the external walls assessed via hygrothermal software - such as WUFI - which will take all of the site variables into account. Internal wall insulation is more complicated than external due to the way it moves the dew point within the construction. In addition, standard U-value calculations will not correctly account for the sorption properties of wood fibres nor their ability to pass on liquid water through capillary action. WUFI purely considers moisture issues and how the various elements of the building fabric will deal with the volumes based on site-specific conditions. STEICO doesn't offer this additional calculation service on a site-by-site basis, but one of their distribution partners, Back to Earth, does. Chris is a great font of knowledge regarding renovation and upgrading of older properties and is a good first point of contact when specifying IWI. Siga & Pro climba with also provide free WUFI assessments if their V-VCL membranes are specified and used in a batten and board approach. 2
Mike Posted January 17, 2025 Posted January 17, 2025 With one reservation (on VCLs) I agree with @sgt_woulds advice, and in particular the recommendation to get the proposal modelled in WUFI - or at least to take manufacturer's advice - since there can indeed be some site-specific peculiarities. For example, from my own experimentation with WUFI, when MVHR is present (it keeps internal humidity down), and when an element absorbs little rain + has a sunny orientation, then the rule-of-thumb on choosing a conservative insulation thickness doesn't necessarily apply; that is, more insulation might reduce condensation risk within the structure, as well as retaining more heat. However, if the element does absorb some rain, then the presence of even an 'smart' vapour control layer may cause a catastrophic build-up of moisture within the structure, as WUFI predicted for the North wall on my current project. In contrast, if the VCL was omitted, then there was no risk. A good illustration of why VCLs aren't a magic wand.
sgt_woulds Posted January 20, 2025 Posted January 20, 2025 True, I should have said 'may need' not 'will need'... This can be determined with a holistic WUFI assessment as no two houses are the same - you need to take into account the location, exposure, construction, state-of-repair, air-tightness, occupancy, and ventilation. IWI requires careful consideration; the breathability and condition of the walls and pointing should always be assessed before specifying the insulation solution; the external brickwork, pointing, roof condition and guttering all need to be assessed and repaired if in poor order to reduce the passage of moisture into - what will become - a colder wall when the insulation is added. No membrane, or insulation, (natural or unnatural) should ever be added until any underlying damp issues have been resolved. Plasterboard and gypsum plaster are - despite what some might claim - breathable, but they are more restrictive than clay or lime and don't work the same way. Natural-fibre insulations and plasters, (e.g. STEICOinternal with a lime plaster) have sorbative qualities that actively absorb and release moisture. This can help where humidity spikes occur, with natural breathable IWI contributing to indoor air quality and comfort. When internal water vapour passes through plasterboard and into natural insulation fibres it can be stored and built up over time. When internal conditions allow drying out, the more restrictive vapour path presented by plasterboards can cause high moisture conditions on the back of the boards - all of which can be exacerbated by any underlying damp issues in building the structure). This moisture will eventually find a way out, but in the meantime in concert with warmer temperatures could cause mould growth and staining. This is why STEICO always recommends V-VCL membranes where its insulation is used behind plasterboards. Admittedly, this moisture could be controlled by the use of MVHR or dehumidifiers to prevent it from entering the insulation in the first place, but this is a less robust approach.
ab12 Posted February 9, 2025 Posted February 9, 2025 On 20/01/2025 at 11:39, sgt_woulds said: This is why STEICO always recommends V-VCL membranes where its insulation is used behind plasterboards. What is V-VCL...VCL= vapour control layer but the initial V? Thanks On 20/01/2025 at 11:39, sgt_woulds said:
MikeGrahamT21 Posted February 9, 2025 Posted February 9, 2025 It’ll be a variable vapour control layer, during the warmer months it allows moisture to pass but not during the colder months 1
