Gary Martin Posted Tuesday at 14:06 Author Posted Tuesday at 14:06 Aero barrier have been and gone. initial air changes per hours was 1.7 builders did an excellent job and AB guys were impressed. after their magic mist was finished, they got it down to 0.2. 4
saveasteading Posted Tuesday at 16:05 Posted Tuesday at 16:05 Great news. Do you mind telling us the cost? I didn't know about this stuff, radweld for houses. Cynical me suspects that the housing developers are already using this on the pre-agreed units for an air test. Does anyone know? They can then apply this to all similar units. ( I know this happens and only assumed that they improved the units that the bco wanted tested.) And as this covers faulty work, the general workmanship may be allowed to fall further. I wonder if it deteriorates with time. So if buying a new house, ask which ones were tested: what chance that info is not to hand?
Mr Punter Posted Tuesday at 16:30 Posted Tuesday at 16:30 So internally insulated block cavity wall. Are the internal walls mostly timber stud (other than the brick one)? Do they go up after the insulation / battens? BTW if you want someone to see you have mentioned them, type "@" and then pick their name from the drop down list @Gary Martin.
ADLIan Posted Tuesday at 17:05 Posted Tuesday at 17:05 Under current Part L in England ALL dwellings should be air pressure tested (was a %age in past).
Gary Martin Posted 5 hours ago Author Posted 5 hours ago IW insulation with air proof membrane and attention to detail got my initial reading down to 1.7 Aero barrier guys. We’re impressed with the workmanship. the magic mist got it down to 0.2 acp cost £2,200 no VAT as self build
Gary Martin Posted 5 hours ago Author Posted 5 hours ago Mr P the internal walls are block, or brick downstairs. There is 50 mm of pir insulation between the internal and external walls ends. starter ties were bolted to the walls, through the insulation to avoid cold bridges. the original plan was stud wall but we preferred this option. all this was completed before AB arrived.
