PeterW Posted November 11, 2017 Posted November 11, 2017 Got a little bit of an issue ... the boss has chosen a very nice limestone flooring that we are using through most of the downstairs. The plant room(s) will both open onto a corridor done in this, but due to a couple of reasons we won’t have the flooring for about 6 weeks. It’s also 22mm thick ..! I need to get the tank and first fix finished so was thinking that as a finished floor (and to bring the level up) I could use self levelling compound on the current floor with a batten to set the door level. Two questions : - assuming it will take the load of a 300litre UVC, will it stand the wear - does it need a finish surface such as paint..? I don’t really want a step down into the plant room of an inch or so if I can help it but that’s the other option. @Nickfromwales...??
Russell griffiths Posted November 11, 2017 Posted November 11, 2017 I had a levelling compound on my garage floor for years without any covering, it stood up well to the jack but not so well to axle stands. Mine was only 3-6 mm thick as I wanted a very flat floor to work on. I did paint it in the end. If i was doing it again I would put an epoxy over it. Maybe if you get a cream colour epoxy it will look similar to the tiles.
PeterW Posted November 11, 2017 Author Posted November 11, 2017 Thanks @Russell griffiths - that was my thoughts from how hard it sets but just wanted some first hand experience ..! I’ll probably go with that and paint it - flooring is black limestone though ..!
Cpd Posted November 11, 2017 Posted November 11, 2017 Just following this as it may be a good solution to an unlevel floor i have, what recomended make / product would you use. Thanks
Stones Posted November 11, 2017 Posted November 11, 2017 Like @Russell griffiths we had self leveling compound on a garage floor. Seemed very robust, and I cannot recall it getting damaged. I didn't do anything to it, although probably should have painted it.
Nickfromwales Posted November 11, 2017 Posted November 11, 2017 2 hours ago, Cpd said: Just following this as it may be a good solution to an unlevel floor i have, what recomended make / product would you use. Thanks Ultra is my weapon of choice.
PeterW Posted November 12, 2017 Author Posted November 12, 2017 Right .... job done ..! Wickes had their latex SLC on offer so it’s worked out about £13 a bag. I learned two things today .... the first is that a bag of SLC and 4 litres of water will fit in a standard Wickes bucket .... The second was that Wickes make their buckets out of recycled milk carton lids and they can’t cope with the weight ...!! Lost about 10% of the first bucket to the utility floor, the rest got mixed in a couple of batches and seemed to be fine when it was mixed into the rest on the floor..... 1
