saveasteading Posted October 12, 2024 Posted October 12, 2024 3 minutes ago, farang said: I was going to record it. Ouch. That would be very off-putting to the professional. They could reasonably refuse to allow it, and you shouldn't without permission: it could count against you even.. They would certainly decline to tell you their initial thoughts, lest it come back to haunt them. A witness is anybody. Partner, neighbour, friend. The best is someone who is a good listener and rememberer, who won't be distracted by the emotion of it. If they send you an email of what they saw and heard then that is a good, dated record. You can do your version to them while it is fresh. 1
scottishjohn Posted October 12, 2024 Posted October 12, 2024 (edited) I agree with all thats has been said and talking nicely is the way forward but surely first thing everyone needs to know is how was it constructed and by whom the general rule is the ground pressure exerted by a retaining wall or indeed any wall will load the gorund at a 45degree angle from the bottom of the wall so if if 45angle hits gound at a level which you have dug down too ,then it might have an effect by same token if it was constructed correctly there should be no load on ground outside their ownership eg bottom of wall is at least twice as thick as the top EG. if 2m high then bottom should be at least 1m then down to 0.5m and with drainage at bottom of wall if more then base needs to be even thicker how high is the wall do they have a drain behind it to stop retained soil turning into mud lots of questions with retaining walls some of which can only be answered by knowing how it was construucted in the first instance and what sort of ground was it constructed on how high and how thick is it and what is it made from to give you an idea look at a gabion basket site and see hoow they are constructed and remeber gabions do not have driange problems --and do not retain water not so with solid walls Edited October 12, 2024 by scottishjohn
farang Posted October 12, 2024 Author Posted October 12, 2024 The wall is about 1.3m high, its dry stone & very old I doubt any foundations to speak of. Its sound apart from where the bushes & small tree are growing. 1
scottishjohn Posted October 12, 2024 Posted October 12, 2024 (edited) 2 hours ago, farang said: The wall is about 1.3m high, its dry stone & very old I doubt any foundations to speak of. Its sound apart from where the bushes & small tree are growing. so it should be at least 2ft thick sounds like old age dry stone dykes fall down with age when they are not used as a retaining wall If it were me and its not i would tell him to just dig it out his side and get a dry stone dyker to rebuild it a days hire with a mini digger and couple of days for a dyker to rebuld it ly would no way class as a retaining wall in the true sense just relying on weight of stone to do the job and iam guessing its not leaning back tohelp the stone stay in situ should be at least a 6degree lean in at top if it was built as a retaining wall Edited October 12, 2024 by scottishjohn 1
farang Posted October 12, 2024 Author Posted October 12, 2024 Iv'e already suggested that they need to dig out & rebuild it, they wont touch it.
joe90 Posted October 12, 2024 Posted October 12, 2024 23 minutes ago, farang said: Iv'e already suggested that they need to dig out & rebuild it, they wont touch it. Well all our talking here won’t solve the problem, let the guy do his inspection and give a qualified opinion 🤷♂️ 1
farang Posted October 24, 2024 Author Posted October 24, 2024 Well i had the site inspection, no pics taken all rather a casual affair. The only thing he said was that the retaining wall is my responsibility. But Ive always thought that unless it states in the land deeds, the land that the wall is holding back is the responsibility of that lands owner?
scottishjohn Posted October 24, 2024 Posted October 24, 2024 1 hour ago, farang said: Well i had the site inspection, no pics taken all rather a casual affair. The only thing he said was that the retaining wall is my responsibility. But Ive always thought that unless it states in the land deeds, the land that the wall is holding back is the responsibility of that lands owner? I would suggest the postion of the wall relative to the boundary will have a bearing on whose responsability it is and who built it to start with If its all on his side then its his problem on the boundary it is shared
farang Posted October 26, 2024 Author Posted October 26, 2024 The fence on top is at the very edge of the wall ( the wall face is the boundary line) The wall is very old. What about the roots on his side pushing the wall out, surely its down to them?
Iceverge Posted October 26, 2024 Posted October 26, 2024 (edited) On 24/10/2024 at 21:05, farang said: The only thing he said was that the retaining wall is my responsibility. Was the retaining wall built originally to allow your garden be lowered artificially below the normal grade? In which case I would say it is your responsibility. The neighbours are entitled not to have their garden fall away because of your failing retaining wall. If the wall was built as a normal dividing wall, and the neighbours built up their garden above the normal grade I would say you were perfectly entitled to do whatever you wanted with your wall. Including removing it entirely or let it fall down and their garden to collapse too. Edited October 26, 2024 by Iceverge 1
Alan Ambrose Posted October 26, 2024 Posted October 26, 2024 OK they acheved their first objective. Ask your solicitor?
joe90 Posted October 26, 2024 Posted October 26, 2024 4 hours ago, farang said: the wall face is the boundary line In that case the wall is built on your neighbours land surely? And as such it is theirs to retain their land 🤷♂️ 1
Kelvin Posted October 26, 2024 Posted October 26, 2024 On 24/10/2024 at 21:05, farang said: Well i had the site inspection, no pics taken all rather a casual affair. The only thing he said was that the retaining wall is my responsibility. Now you know their motivation for the inspection. Expect a follow up letter. I’d get all your ducks in a row now to establish whose responsibility the wall is. It might also be worth having your inspection done to get an ‘expert’ opinion on why the wall is failing rather than just your opinion it’s the roots of their bushes. 1
farang Posted October 26, 2024 Author Posted October 26, 2024 The wall is very old, well over 100 years. The property's where built going up a hill, & the gardens terraced with retaining walls. The gardens & their retaining walls all built at the same time, .
scottishjohn Posted October 26, 2024 Posted October 26, 2024 (edited) 22 minutes ago, farang said: The wall is very old, well over 100 years. The property's where built going up a hill, & the gardens terraced with retaining walls. The gardens & their retaining walls all built at the same time, . sounds simple to me its their wall so send them a letter outlining what you know that it is on their ground and if it collapses your solicitor will be sending them the bill to remove the remains from your property by a contractor of your choosing that should do it and spend no nore and wait for the reply ,assuming you can pove what you have just said in your post Edited October 26, 2024 by scottishjohn 2
Iceverge Posted October 27, 2024 Posted October 27, 2024 Can you look at the back gardens of the houses at the top of the hill and the bottom of the hill as see what side the remaining wall is of their property. It should give you a clue as to what wall each house owns as everyone should only have one wall. Pick the incorrect one and the house at the top will have 2 and the bottom none or visa versa.
farang Posted October 27, 2024 Author Posted October 27, 2024 Im at the bottom of the hill,,I have no retaining wall, the house at the top has one retaining wall holding their land level.
joe90 Posted October 27, 2024 Posted October 27, 2024 11 hours ago, Iceverge said: It should give you a clue as to what wall each house owns as everyone should only have one wall. 23 hours ago, farang said: ( the wall face is the boundary line) Therefore the wall is built on your neighbours land and their responsibility. On 24/10/2024 at 21:05, farang said: The only thing he said was that the retaining wall is my responsibility. Based on what evidence? (See above) 14 hours ago, scottishjohn said: so send them a letter outlining what you know that it is on their ground and if it collapses your solicitor will be sending them the bill to remove the remains from your property by a contractor of your choosing +1
Conor Posted October 27, 2024 Posted October 27, 2024 Right. A 100 year old retaining wall can be assumed to be well beyond it's design life and in need of replacement. The question then is who is responsible for its upkeep and ultimate replacement? You could argue that if the wall forms part of a boundary, and only one party (you) has access, then therefore you are responsible for its upkeep and condition. And if lack of upkeep has resulted in early failure, then it's not unreasonable that you could be partly or wholly responsible for its replacement. But that's only one argument. And I'm sure there is legal precedent one way or the other, but that's not my realm. The other is when it was built and who built it, and why? If, as you allude to, it was built by the neighbour (original developer/leaseholder) in order to allow the building and landscaping of their property, and is sited within their boundary, you can argue it's FA to do with you. You (rather the original leaseholder) can easily argue that you are a mere third party in the matter. It could end up being a load drawn out and exhaustive experience. Getting a price for the works required could be a wise first step.
Iceverge Posted October 28, 2024 Posted October 28, 2024 21 hours ago, farang said: I'm at the bottom of the hill,I have no retaining wall, the house at the top has one retaining wall holding their land level. Ok so your saying there's just a wall between each house and none at either end. For example 10 houses and 9 walls?
farang Posted October 28, 2024 Author Posted October 28, 2024 On the hillside, we have houses going up the hill, some are detached others not, at the rear they have strip gardens, these gardens are leveled out with retaining walls, yes 8 homes & 7 retaining walls.
joe90 Posted October 28, 2024 Posted October 28, 2024 Despite all the above I still say if it’s built on your neighbours land as you indicate the boundary line is the face of the wall it’s not yours 🤷♂️
Alan Ambrose Posted October 28, 2024 Posted October 28, 2024 >>> yes 8 homes & 7 retaining walls. Then maybe some of the neighbours have decided this issuse before?
saveasteading Posted October 28, 2024 Posted October 28, 2024 As above. Photo? It seems you don't want to or maybe don't have access. But it would explain so much, and perhaps we'd see something significant that you don't. Otherwise, we're not making progress.
