Ferdinand Posted November 9, 2017 Share Posted November 9, 2017 Is Durisol suitable for a garden wall - say a 2m high wall enclosing a back garden, either on the boundary or as a divider? In the past all sorts of materials have been used for garden walls which are then rendered over and capped at the top. I am wondering if Durisol could be used for such a purpose, as it is inexpensive, fast, easily incorporates reinforcement, and is suitable for render. The full above ground sections can probably be done as a single pour after an earlier pour for the foundations, and perhaps the copings can be plonked straight on top of *that*. Compared with the cost of a traditional brick or stone wall, that looks attractive. Does anyone have any thoughts? Ferdinand Link to comment Share on other sites More sharing options...
PeterW Posted November 9, 2017 Share Posted November 9, 2017 I wonder if @recoveringacademic has a pile of scrap durisol modules for someone to give this a try ..?? I know that Beco have been used for garden walls as it’s in their brochure. Very quick and easy and once rendered you can’t tell the difference to blockwork. Link to comment Share on other sites More sharing options...
Ferdinand Posted November 9, 2017 Author Share Posted November 9, 2017 I have one block he gave me ,so I can try a small garden wall :-). F Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 9, 2017 Share Posted November 9, 2017 Yes. I am building one next week (Yeah, right) . I'll post piccies. It'll be a good place to use up our spare rebar (but there's no need for it). As part of our plan, I want to create little 'slots' in the wall to grow wall plants and other local wall-loving bits and bobs. So during the pour, I'll drop some suitable PIR blocks in place and then spray the block so I can't forget which block contains the plastic. When it's all cured, it should be easy enough to dig out the block and plastic and then pop some grow modules in next spring. I am also keen to encourage our Great Crested Newts to use bits of the wall as a hibernacular. To that end, I'll leave some rubble in one or two of the blocks and make some small holes into which they can wriggle and so have a completely safe winter snug. Those blocks will need a bit of rebar to connect them vertically and horizontally. I'll also allow a clear slot at ground level to enable them to go through it if they want to Learning from the experience of building the house, I'll incorporate some metal ducting and build a few discrete lights into the wall. Cost? A few mixers worth of concrete per meter for a wall 2 meters high. Cost of the blocks? 4 square meters £60. Time to build? A day, tops. The foundation costs more than the wall. (But has already been built) Render? Here's how quick and easy it is (should be). Cost? Bit of sand and some cement and a soft old house brush, some elbow grease. Overall price for absolutely everything for a 2 by 3 meter wall with a corner built in, lights, and hibernacular, and spaces for wall plants, slot for a side-door: £300. Link to comment Share on other sites More sharing options...
Jml Posted November 9, 2017 Share Posted November 9, 2017 1 hour ago, Ferdinand said: Is Durisol suitable for a garden wall - say a 2m high wall enclosing a back garden, either on the boundary or as a divider? In the past all sorts of materials have been used for garden walls which are then rendered over and capped at the top. I am wondering if Durisol could be used for such a purpose, as it is inexpensive, fast, easily incorporates reinforcement, and is suitable for render. Compared with the cost of a traditional brick or stone wall, that looks attractive. 19 minutes ago, recoveringacademic said: Overall price for absolutely everything for a 2 by 3 meter wall with a corner built in, lights, and hibernacular, and spaces for wall plants, slot for a side-door: £300. What cost would you expect for the same in blockwork and rendered? Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 9, 2017 Share Posted November 9, 2017 @Jml, I have no idea. The above guestimate prices my labour at zero. It would also be a bit more complex to do the fiddly bits, like incorporate the hibernacular, and run an armored cable inside the wall. A Durisol wall is mostly concrete, and fresh air (the blocks are 65% air) Discussions about Durisol eventually focus in large part on the skill base needed to build with it. That's not to say it's complex: its the opposite. But it makes a fair comparison of price difficult. Link to comment Share on other sites More sharing options...
Ferdinand Posted November 9, 2017 Author Share Posted November 9, 2017 (edited) The prices for having the work done I would expect - very much guestimates since my last garden wall was a barter deal. 9 inch brick garden wall 2m high = 2.4m high incl. 2.4m foundations incl materials. £400-500 per metre run. In stone would be perhaps £600-700 per metre run. Rendered breeze block In block I would guestimate £10 per sqm for blocks to be laid, £12 per sqm for materials, and £25 per sqm for render materials and labour. That is £40-45 per sqm or £150 per metre run with founds at £30 per metre. Please shoot this down as I am not familiar with the costs in detail. Coping would be on top of that. By comparison stout concrete 100mm post / gravel board / vertilap (i.e. Way beyond diy shed quality) panel fence would be about £50 per metre run. Of that about 30 per metre is materials. Was after alternatives that make garden walls realistic for me to have built, as I like them. I really want a cost of £200-250 per metre run for a 2m 9" wall built by somebody I employ, all in. Ferdinand Edited November 9, 2017 by Ferdinand Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 9, 2017 Share Posted November 9, 2017 29 minutes ago, Ferdinand said: [...] I really want a cost of £200-250 per metre run for a 2m 9" wall built by somebody I employ [...] That is more than achievable with Durisol. I suspect that other ICF walls would be roughly the same. Link to comment Share on other sites More sharing options...
Ferdinand Posted November 9, 2017 Author Share Posted November 9, 2017 (edited) 29 minutes ago, recoveringacademic said: That is more than achievable with Durisol. I suspect that other ICF walls would be roughly the same. Can you tell me an approx factory gate or delivered price of the Durisol blocks without insulation eg the D250 or D170 options for a pack or 10 packs of 50 or 60 (resp.)? Aside to anyone: basic Durisol blocks are 250mm x 500mm x varying thicknesses so the coverage is 8 blocks per sqm. eg D250 is 250mm thick. Getting a price out of Durisol UK is like gaining enthusiastic consent from Esther Ransome to have her teeth pulled with a doorhandle. Ferdinand Edited November 9, 2017 by Ferdinand Link to comment Share on other sites More sharing options...
Ferdinand Posted November 9, 2017 Author Share Posted November 9, 2017 (edited) Unable to obtain a price from Durisol UK, so this price list from Hungary quotes a price of 800 Forints for a D250 non-insulated block which is called a 25/16 unit. At today's exchange rate that is £2.27 per block or £20 per sqm, or £50 per metre run on blocks for a 2.4m high wall. So we have based on a cost for Durisol D250 blocks at about £20 per sqm, £10 per sqm labour, and £5 per sqm concrete. Rules of thumb suggest Durisol 250mm garden wall 2.4m high (400mm below ground) with 50% concrete content at £100 pcm concrete should therefore be around £100-110 per meter run plus bits and pieces. Bet UK made Durisol blocks are not £2.27 each for a D250 . Ferdinand Edited November 9, 2017 by Ferdinand Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 9, 2017 Share Posted November 9, 2017 20 minutes ago, Ferdinand said: Unable to obtain a price from Durisol UK,[...] That is not on. I will point the Durisol North rep to this thread and let them sort it out. email and voicemail sent. Ian Link to comment Share on other sites More sharing options...
Ferdinand Posted November 9, 2017 Author Share Posted November 9, 2017 (edited) 4 minutes ago, recoveringacademic said: That is not on. I will point the Durisol North rep to this thread and let them sort it out. email and voicemail sent. Ian I thought they would have a list on the website, but they seem to want to price in the context of each project. Edited November 9, 2017 by Ferdinand Link to comment Share on other sites More sharing options...
MikeSharp01 Posted November 9, 2017 Share Posted November 9, 2017 (edited) 5 hours ago, recoveringacademic said: I am also keen to encourage our Great Crested Newts to use bits of the wall as a hibernacular Good to see that you have grown to appreciate the little critters given what you have alluded to in the past about them? Edited November 9, 2017 by MikeSharp01 Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 9, 2017 Share Posted November 9, 2017 We have always loved them @MikeSharp01. They are singularly inoffensive, beautifully marked, shy, creatures. For me, its the shapes they cast that makes them so interesting. And their young.... When they gently shuffle across the kitchen floor looking for all the world like a piece of delicate jewelry, the size of a girl's wrist charm, almost as translucent as a bit of amber, its all I can do not to pick them up. Sid, our tomcat, sits and growls at them. Wont even approach them Link to comment Share on other sites More sharing options...
PeterW Posted November 10, 2017 Share Posted November 10, 2017 On 09/11/2017 at 16:45, recoveringacademic said: We have always loved them @MikeSharp01. They are singularly inoffensive, beautifully marked, shy, creatures .... which are lovely when served with a slightly piquant sauce and stir fried vegetables ..... Link to comment Share on other sites More sharing options...
Dutch Posted March 5, 2022 Share Posted March 5, 2022 What size of rebar is needed ? how many per block ? Link to comment Share on other sites More sharing options...
JohnMo Posted March 6, 2022 Share Posted March 6, 2022 If you are not retaining anything, (IE just a wall) not sure you would need any rebar. But it depends on how high wide you make it. Download the Durisol manual and/or speak to them. 9 hours ago, Dutch said: What size of rebar is needed ? how many per block ? Link to comment Share on other sites More sharing options...
