messed up a kitchen wall (metro tiles)
johnhenstock83
right...
the missus kept nagging about the wall behind the worktop, she wanted tiles. so I went and bought metro tiles (200x100), tile adhesive, tile cutter, spacers, trowel, the lot. everything prepared nicely, wall scratched in a zig zag pattern for better grip, tiles cut to the milimeter, what could go wrong, right?
I don't know what made me buy the £10 grey powder adhesive from screwfix, I thought it's good enough for a basic job such as this one. I guess not. despite mixing it properly and in the EXACT quantity recommended, I ended up with a paste that couldn't hold anything in place, definitely not a tile. each and every tile kept "flowing" downwards, so I scraped the walls, threw everything away and now I'm frustrated.
the adhesive looked very much like cement, not the typical adhesive I've been using for years (white, fairly thick, easy to spread). what was that??? and who uses it?
Pretty sure that powder is for walls and floors. I used powder for all my walls - the difference between the two is how they cure. The powder is by chemical reaction, the paste by drying out.
If the tiles are slipping it sounds like the mix is sloppy. I've tiled the ceiling of my steamroom using a powdered adhesive with no issues.
A good professional tiler uses a quick setting adhesive, from powder, and holds the tile for 20 seconds...and it stays put.
Amateurs use slow setting adhesive to allow for adjustment, and spacers hold it in place.
I suggest you go to a tile merchant and get some stickier stuff, and spacers. Tell them and they will be helpful.
