jayc89 Posted August 18, 2024 Share Posted August 18, 2024 I'm using one of these linear wet room trays - https://www.drawabath.co.uk/abacus-elements-1800-x-900mm-infinity-level-single-fall-wetroom-shower-tray-kit-1000mm-offset-linear-drain.html - in the instructions it recommends tiling the walls before the floor for better water run off. Do I need to do that for the entire room or just the wall behind the drain? Link to comment Share on other sites More sharing options...
Onoff Posted August 18, 2024 Share Posted August 18, 2024 That's b***ocks. Floor first, right up to the wall. Then bring the wall tiles down onto them with a 1mm gap. Seal with CT1, wipe flush. When set put a silicone bead on which you can periodically replace. A Welsh wizard once told me that. 2 Link to comment Share on other sites More sharing options...
Pocster Posted August 18, 2024 Share Posted August 18, 2024 Also , best make sure room is dry first 😉 Link to comment Share on other sites More sharing options...
nod Posted August 18, 2024 Share Posted August 18, 2024 1 hour ago, jayc89 said: I'm using one of these linear wet room trays - https://www.drawabath.co.uk/abacus-elements-1800-x-900mm-infinity-level-single-fall-wetroom-shower-tray-kit-1000mm-offset-linear-drain.html - in the instructions it recommends tiling the walls before the floor for better water run off. Do I need to do that for the entire room or just the wall behind the drain? Yes Never tile the floor before the wall on any tiling job Link to comment Share on other sites More sharing options...
jayc89 Posted August 18, 2024 Author Share Posted August 18, 2024 6 hours ago, Onoff said: That's b***ocks. Floor first, right up to the wall. Then bring the wall tiles down onto them with a 1mm gap. Seal with CT1, wipe flush. When set put a silicone bead on which you can periodically replace. A Welsh wizard once told me that. 4 hours ago, nod said: Yes Never tile the floor before the wall on any tiling job Well that was my thoughts too, but the instructions explicitly say walls first for some reason... Floor it is. Link to comment Share on other sites More sharing options...
nod Posted August 18, 2024 Share Posted August 18, 2024 34 minutes ago, jayc89 said: Well that was my thoughts too, but the instructions explicitly say walls first for some reason... Floor it is. That’s correct Walls first 1 Link to comment Share on other sites More sharing options...
Onoff Posted August 18, 2024 Share Posted August 18, 2024 (edited) I did floor first then protected the floor with Correx. I then used a homemade tile levelling system to place the second tile up. For the bottom tile I turned it over, placed it on 1mm packers and marked the cut line with the laser. When you turn it back it's bang on: (I should add I can't tile to save my life! Up until then the wall boarding was all perfectly square 😂). Edited August 18, 2024 by Onoff 1 Link to comment Share on other sites More sharing options...
jayc89 Posted August 18, 2024 Author Share Posted August 18, 2024 I did floor first in the downstairs W/C and it looks spot on. Not sure why they suggest doing walls first for a wet room... Link to comment Share on other sites More sharing options...
Chanmenie Posted August 19, 2024 Share Posted August 19, 2024 17 hours ago, nod said: Yes Never tile the floor before the wall on any tiling job Why’s that ? it seems most tile the floor first Link to comment Share on other sites More sharing options...
nod Posted August 19, 2024 Share Posted August 19, 2024 32 minutes ago, Chanmenie said: Why’s that ? it seems most tile the floor first Most definitely don’t There’s a number of reasons The first one being that the floor would be damaged marked or stained Also if anything is likely to move it’s the floor Chipping the bottoms of the wall tiles Also if the floor is running out which most are It’s neater to do the walls first 1 Link to comment Share on other sites More sharing options...
Vijay Posted August 19, 2024 Share Posted August 19, 2024 I fitted one of these for my parents and I'd never fit one again! They look amazing but weren't well made and Abacus couldn't care less. A year or so down the line, the plastic guttering/drain cracked and leaked. I had to break the ceiling from underneath to fix it which was an absolute headache Link to comment Share on other sites More sharing options...
Onoff Posted August 19, 2024 Share Posted August 19, 2024 If you do floor first then the wall tiles come down onto them. A much better detail in terms of waterproofing and no horrible grout line at the edge where the floor and wall meet. Link to comment Share on other sites More sharing options...
Onoff Posted August 19, 2024 Share Posted August 19, 2024 10 minutes ago, Vijay said: I fitted one of these for my parents and I'd never fit one again! They look amazing but weren't well made and Abacus couldn't care less. A year or so down the line, the plastic guttering/drain cracked and leaked. I had to break the ceiling from underneath to fix it which was an absolute headache I cast my floor to falls in the wet room corner and it's stayed perfect. Took some working out along with the Geberit wall drain. I'd do it again in a heartbeat but next time use a tile levelling system. 2 Link to comment Share on other sites More sharing options...
jayc89 Posted August 19, 2024 Author Share Posted August 19, 2024 1 hour ago, Vijay said: I fitted one of these for my parents and I'd never fit one again! They look amazing but weren't well made and Abacus couldn't care less. A year or so down the line, the plastic guttering/drain cracked and leaked. I had to break the ceiling from underneath to fix it which was an absolute headache I had to send the first tray back because it was damaged around the drain. If it's not supported well from below I can see there being plenty of flex around it. Link to comment Share on other sites More sharing options...
nod Posted August 19, 2024 Share Posted August 19, 2024 14 hours ago, Onoff said: I did floor first then protected the floor with Correx. I then used a homemade tile levelling system to place the second tile up. For the bottom tile I turned it over, placed it on 1mm packers and marked the cut line with the laser. When you turn it back it's bang on: (I should add I can't tile to save my life! Up until then the wall boarding was all perfectly square 😂). Looks good to me Link to comment Share on other sites More sharing options...
Onoff Posted August 19, 2024 Share Posted August 19, 2024 1 hour ago, nod said: Looks good to me You're too kind. Up close you could hang your coat on the walls. Boy did I learn a lot doing it though. Link to comment Share on other sites More sharing options...
Conor Posted August 19, 2024 Share Posted August 19, 2024 On 18/08/2024 at 12:25, jayc89 said: I'm using one of these linear wet room trays - https://www.drawabath.co.uk/abacus-elements-1800-x-900mm-infinity-level-single-fall-wetroom-shower-tray-kit-1000mm-offset-linear-drain.html - in the instructions it recommends tiling the walls before the floor for better water run off. Do I need to do that for the entire room or just the wall behind the drain? We've one of those. They're shite. Base is soft, ours was deformed and a pain to install. Barely any fall on it and if water goes past a certain point, it pools in the corner. Tiler did best he could. Link to comment Share on other sites More sharing options...
jayc89 Posted August 19, 2024 Author Share Posted August 19, 2024 5 hours ago, Conor said: We've one of those. They're shite. Base is soft, ours was deformed and a pain to install. Barely any fall on it and if water goes past a certain point, it pools in the corner. Tiler did best he could. The first one we had delivered was similar, so I rejected it. A second one arrived and seems much better, albeit bowed when I fixed it down on a bed of adhesive. Some additional weight whilst it was setting seemed to sort that out though. These comments aren't sounding too promising though! Link to comment Share on other sites More sharing options...
Vijay Posted August 20, 2024 Share Posted August 20, 2024 20 hours ago, jayc89 said: I had to send the first tray back because it was damaged around the drain. If it's not supported well from below I can see there being plenty of flex around it. Yep but I did timberwork to support it, but it still failed Link to comment Share on other sites More sharing options...
Vijay Posted August 20, 2024 Share Posted August 20, 2024 13 hours ago, jayc89 said: The first one we had delivered was similar, so I rejected it. A second one arrived and seems much better, albeit bowed when I fixed it down on a bed of adhesive. Some additional weight whilst it was setting seemed to sort that out though. These comments aren't sounding too promising though! exactly how I installed it, used blocks to weigh it all down when installing it. Link to comment Share on other sites More sharing options...
Chanmenie Posted August 20, 2024 Share Posted August 20, 2024 On 19/08/2024 at 08:43, nod said: Most definitely don’t There’s a number of reasons The first one being that the floor would be damaged marked or stained Also if anything is likely to move it’s the floor Chipping the bottoms of the wall tiles Also if the floor is running out which most are It’s neater to do the walls first Well fortunately for me my floor is concrete so won’t be moving, and it is very level, I was thinking of doing floor first and covering it with Protec sheets as I agree with the possibility of it getting damaged Link to comment Share on other sites More sharing options...
