DannyT Posted August 13, 2024 Posted August 13, 2024 What’s going in there? Mine will be about half that for ASHP cylinder and solar batteries, inverters, etc.
JohnMo Posted August 14, 2024 Posted August 14, 2024 On 12/08/2024 at 16:24, BotusBuild said: How big is it? What's going in there? Have you planned it out?
BotusBuild Posted August 14, 2024 Author Posted August 14, 2024 It was a rhetorical question 😁 But answer your Qs: Yes it's been planned. HWC Buffer tank for UFH UFH manifold for lower floor The electrical CU's A comms cabinet The MVHR (already there on the right) H & C manifolds ( to those pipes on the left) 1
TerryE Posted January 29 Posted January 29 Mine is a 0.8 × 1.4 m cupboard off the downstairs loo. 🤣 The electrical panel and OSO UVC (a later SunAmp replacement) are in the utility. The MVHR is in the loft floor drying / storage room. 2
MikeSharp01 Posted January 29 Posted January 29 Looking good, how are the pipe stands from the top tundish fixed to the ply wall?
BotusBuild Posted January 30 Author Posted January 30 Same as the one you can see clearly at the front - metal clip with rubber
Nickfromwales Posted January 30 Posted January 30 15 hours ago, MikeSharp01 said: Looking good, how are the pipe stands from the top tundish fixed to the ply wall? These bad boys
MikeSharp01 Posted January 30 Posted January 30 2 hours ago, Nickfromwales said: These bad boys That is what I thought but zooming in you can see that it is not - looks like either nutserts, see below, or a bolt with the head on the wall side of the board, which is why I asked. 1
Nickfromwales Posted January 30 Posted January 30 Ah, yes, more zooming-in for me from now on lol. It wouldn’t surprise me if the threaded bar isn’t just wound into a slightly undersized pilot hole, maybe with a bit of mastic.
