We are looking to install something along the sleeper walls in the picture, predominantly for safety as we have a toddler and a newborn, but also we want it to look nice! Glass balustrades were an option but have just had a quote of £5k for the 8.5 metres which is well out of our budget so am Just looking for some more suggestions as to what we can do?
thanks in advance
I'd just put up a low level timber fence for a couple of years, your kids will soon wanting to be jumping and playing off it!
How would you fix it in, posts coming up from the stones, screwed to the sleepers and run it off that? Don’t really want to concrete into the stone border
Are the sleepers pinned to each other and to the ground, or it gravity holding them there?
I would fence posts with ground spikes in, then a slatted fence across. Height of fence would be 1.1m for building regs, but as it doesn't apply here really, as high as you want.
Why wouldn't it apply the fall is there and is great enough that fall protection is required. Trouble is not doing it correctly, is just as likely to cause issues, same as not having there at all.
Because its not getting building regs sign off, this is as built at the moment it's not meeting current building regs as it stands. it's not notifiable works. Its just a guy wanting to protect his toddler from a fall (which is fair enough) and he can make it as high as they see fit and don't have to met building regs.
I had a similar drop on my build and the bco wanted it fenced / barrier to min 1100mm to meet current regs and sign off. We put in a low fence and all was good.
Sorry not agreeing - I will bow out and leave you to it.
Posts behind the sleepers which they are screwed to, and then sleepers screwed to each other
Not sure why the convo has got into building regs etc! As moonshine said I’m just looking to do something to protect the toddler!!
Glass ballastrade at decent prices and good delivery
https://www.made2measure.co.uk/post-and-saddle-system/
Did a quick cost and it's about £1k for glass with posts
Because if the fall is more than 600mm it has to comply with building regs. First bullet point in the attached.
Screenshot_2024-06-15-08-45-40-34_40deb401b9ffe8e1df2f1cc5ba480b12.thumb.jpg.a769b3e78b855d927976ccca594d0844.jpg
It doesn't (appear to) form part of an access route to / from the house so is considered landscaping and BC does not apply.
Yeah it’s fully landscaping surely, it’s out in the garden!
I'd just be putting in a picket style fence using vertical 25x50mm battens fixed to the back of the sleepers. Put some nice climbers against them. Id view it more as a deterrent for the kids to climb... Pointy sticks and growth will do that well!
Back of sleepers no accessible as is backfilled
That looks good. What length did you put in to get it to around 1k? Seems more than that for me
If posts are driven down the back of the sleepers and fixed at the top this will resist any leverage. Just don’t put horizontal timbers that can be used as a ladder by the kids, vertical picket style much safer (and prettier IMO).
Two L shapes 1.5 x 3m.
Ended up getting 4 quotes for this:
3.3k
3.5k
4.3k
5k
Quite a range and more than I anticipated. Need to re-think options - any more ideas as to what we could opt for instead of glass?
I did that on our brick retaining wall when our kids were toddlers. Removed later as earlier stated by someone. Would re-used on several other projects over the years. Only recently took the last of that wood to the tip (26 years later)
