I have a dilema regarding heat/smoke and carbon monoxide alarms for my house.  In each of my living rooms specifically I require both a smoke and carbon monoxide alarm to which I dont want to have 2 stuck in the ceiling along with MVHR outlet.  Combined offerings seem to be limited with none from Aico which seems to be a favourite on here.  Nest is a combined offering but the cost puts me off as I would need to put these throughout the house to satisfy the linked system requirement, needing 6/7 puts me off.
Anyone any further suggestions?
Got to ask why....
CO is only needed where there is a combustion device (stove, fire, boiler) so unless you've got a lot of those then you shouldn't need them in every room..?
@PeterW my original post is misleading slightly, we have 2 rooms that have wood burning stoves so both smoke and CO sensors required.  If we were to use nest in these then we would be bound to use nest in the rest of the house to satisfy the linking of the smoke alarms is my understanding.  That would then equate to 6/7 units.
Kidde do one but it’s 9v only I think. They also do a decent range of linking ones
also bear in mind the CO sensor requirement for location is different to that of a smoke alarm ...
What annoys me though, is you can't find a CO and a smoke detector that look the same, i.e Aico smoke and heat detectors re round, but their CO detectors are rectangular. WHY?
1 hour ago, PeterW said:
Aico CO are round ........ or the one I bought last week was I’m sure ..!!!
the only mains powered aico CO alarms I can find are these
https://www.aico.co.uk/product/ei261enrc-mains-powered-co-alarm/
https://www.aico.co.uk/product/ei225en-carbon-monoxide-alarm/
Neither are what I would describe as round.
the only round one seems to be this https://www.aico.co.uk/product/ei208dw-carbon-monoxide-alarm/ which is battery powered
Yeh sorry @ProDave..!! I looked at the bleedin heat alarm ..!!
CO is rectangular but at 6.3m up I don’t think anyone will care ....
As much as I like Aico, for the ease of installation and termination, if I can find another make that has a CO alarm to match the heat and smoke alarms I will be choosing that instead. (if anyone knows such a make....?)
9 minutes ago, Declan52 said:
Since we are talking about smoke alarms how do you get one to stop chirping even after a new battery is put in.
Replace it :ph34r:
9 hours ago, Declan52 said:
It's in my mum's house and that's what I told her but thought maybe there was some trick I was unaware of
Check the battery terminals. I had one that went like this, and it turned out that the terminals inside the unit were dirty and a bit corroded.  A rub with a bit of Scotchbrite followed by a smear of vaseline on the terminals got it working again.
Also, check the new battery.  I've pulled a new one out of the drawer before now only to find that it's gone flat from being stored for too long, and was out of date................
