joshwk Posted June 9 Share Posted June 9 (edited) Hi all. We will be constructing our self-build in SIPs and I was curious to understand if there is a school of thought on 'diminishing returns' when it comes to wall thickness and U-value effectiveness. I realise the black and white answer is 'the lowest u-value is the best' and that there is a significant variable in the form of cost, but what I am curious to understand is if there is any general thinking on what a 'sweet spot' might be when it comes to investing into additional PIR vs the incremental gains made from improving u-value? Currently, I am approaching our build on the basis that walls would be 142mm + 25mm PIR to achieve a u-value of 0.15 and roof would be 142mm + 75m PIR to achieve a u-value of 0.11 but am wondering if I should be looking to improve the wall insulation further? Our property is not excessively large (~200sq/m total) so I am also conscious of trying to maximise room sizes. We are not going for Passivhaus but as this will be our 'forever home', I'm keen to ensure I'm building out house with the long term in mind. I have included a table below that we received from our SIPs supplier for visibility in case helpful. Thanks in advance. Walls U-Value Table Roof U-Value Table Walls + Roof Summary Edited June 9 by joshwk Link to comment Share on other sites More sharing options...
JohnMo Posted June 9 Share Posted June 9 People will say this is quite black and white, but it's not. One thing often missed is house form factor. So a house that is a cube is great, you need very little insulation to heat a low W/m2 heating required. However my house is rubbish it's long and thin, single storey, with vaulted ceilings in every room. So although all surfaces are insulated to better than advertised PH requirements it's energy inputs are way higher. Your house as far as form factor goes is about as bad as it gets. Lots of external walls, roof and floor for a given m2. So cram as much insulation in as you can get away with. Aim for 0.1 U values or better everywhere. Link to comment Share on other sites More sharing options...
joshwk Posted June 9 Author Share Posted June 9 Thanks @JohnMo, that's a great callout. Very helpful. Link to comment Share on other sites More sharing options...
SteamyTea Posted June 9 Share Posted June 9 Another thing to add in is the local weather regime. There is little difference in mean temperatures across the UK. There is quite a difference in how they are distributed though. So West Cornwall may have a similar mean temperature to Hull, but the extremes are closer to the mean. Sunshine hours are also different, which can make a difference to cooling costs. 3 years ago when people where paying 2.5p/kWh for gas and 12p/kWh for electricity, there was a case to be made for just meeting building regulation levels. But different now that gas is 7.5p and electric 30p. And then there is airtightness. More energy can be lost through this than through walls, floors and roofs. The much mentioned Jeremy Harris spreadsheet was originally designed to compare price comparisons to help establish best value for money. Easy enough to use it as such, just fill in different numbers and see what it churns out. One word if caution, if anyone says that "it meets building regs', or 'airtight houses overheat', walk away from them, they will do a bad job. 1 Link to comment Share on other sites More sharing options...
Iceverge Posted June 9 Share Posted June 9 Do the best you can is the only thing I can say. I used PHPP and my own spreadsheet to refine the insulation levels. In terms of money spent to improve energy efficiency it's a little further down the list than you might expect. From memory the best bang for your buck was 1.Airtightness 2.MVHR 3. 3g Windows 4. Roof insulation 5. Wall insulation 6. Floor insulation. The metric I used was payback years. EG an extra 100mm of attic insulation might take 30 years to payback and and extra 150mm might take 50 years. I started at bRegs and worked my way up year by year until everything was at 25 years payback. I stopped there as I was at passivhaus performance and a bit extra. At least I knew then I was spending our cash in as balanced a manner as possible. In the end I had 450mm cellulose in the attic, 250mm EPS bonded beads in the wall, 200mm EPS70 in the floor. I could have probably put 300mm everywhere but in our case it would have been dearer for the same result as the floor insulation was much dearer than the cellulose. Link to comment Share on other sites More sharing options...
SBMS Posted June 9 Share Posted June 9 (edited) Have you looked at a thicker SIPS panel to do away with the 25mm insulation? Edited June 9 by SBMS Link to comment Share on other sites More sharing options...
joshwk Posted June 10 Author Share Posted June 10 (edited) Good tips, thank you @SteamyTea & @Iceverge. @SBMS: 142mm appears to be the standard manufacturing for TEK Kingspan. 172mm is also possible but requires additional work in cutting transition materials down to suit the non standard wall panels width (quoting the images shown above). Per the table, 172mm with no additional insulation is estimated to achieve a 0.16 U/value. To achieve close as close to a 0.1 U/value as possible based on @JohnMo's suggestion, in my personal situation, I think the best route is to use 142mm but upgrade from +25mm to +75/80/90mm to achieve a 0.11 on the walls (in line with the current estimated U-Value for the roof). Edited June 10 by joshwk Link to comment Share on other sites More sharing options...
Iceverge Posted June 10 Share Posted June 10 I'm not a massive fan of SIPs in general as they have issues with thermal bridging at junctions. If I was going to upgrade them I would probably opt for a layer of something like mineral wool to reduce this. How is your external skin going to be constructed? Brick/blocks or cladding hung from the SIPS. Link to comment Share on other sites More sharing options...
SBMS Posted June 10 Share Posted June 10 4 hours ago, joshwk said: Good tips, thank you @SteamyTea & @Iceverge. @SBMS: 142mm appears to be the standard manufacturing for TEK Kingspan. 172mm is also possible but requires additional work in cutting transition materials down to suit the non standard wall panels width (quoting the images shown above). Per the table, 172mm with no additional insulation is estimated to achieve a 0.16 U/value. To achieve close as close to a 0.1 U/value as possible based on @JohnMo's suggestion, in my personal situation, I think the best route is to use 142mm but upgrade from +25mm to +75/80/90mm to achieve a 0.11 on the walls (in line with the current estimated U-Value for the roof). There's a local company near us that do a 195mm SIPS panel that achieves 0.13 U value. Or a 140mm that achieves 0.16. https://flitcraft.co.uk/injectawall/ Out of interest, have you modelled the difference between a 0.16 and a 0.1 u value? Its about a £80 in additional energy costs per annum when modelled for our build (YMMV, but its worth checking). Link to comment Share on other sites More sharing options...
MikeSharp01 Posted June 16 Share Posted June 16 On 09/06/2024 at 17:35, Iceverge said: From memory the best bang for your buck was 1.Airtightness 2.MVHR 3. 3g Windows 4. Roof insulation 5. Wall insulation Do you recall your methodology for working this out? Did you use just savings in energy input or this and / or other factors? Link to comment Share on other sites More sharing options...
G and J Posted June 16 Share Posted June 16 I took best bang for your buck to mean final heating requirement vs total build cost. Sounds easy when it’s in a list like that but I’m finding out that there’s soooooo many factors. Link to comment Share on other sites More sharing options...
Iceverge Posted June 17 Share Posted June 17 9 hours ago, MikeSharp01 said: Do you recall your methodology for working this out? Did you use just savings in energy input or this and / or other factors? I started with a bRegs basic house. Double glazing, natural ventilation, minimum insulation and 5ACH. I assigned a realistic cash value to every upgrade of the fabric. Obviously some were either there or not like the 3g and triple glazing buy others like airtighess and insulation I stepped up gradually. I then fed them into PHPP and looked at the annual heat demand reduction for each upgrade. I costed energy at the time at 10c/kWh and noted the payback of the upgrade. For example if MVHR cost €3000 but saved 1500kWh/year @ 10c/kWh = €150. €3000/€150 = 20 year payback. Anything that paid back in less than 25 years at the time got the thumbs up. It was a bit of an arbitrary target but I felt that it was at least a balanced and economic method of spending money. 1 Link to comment Share on other sites More sharing options...
Kelvin Posted June 17 Share Posted June 17 I did something similar but being a bit older the payback period matters slightly less. Therefore I considered it both in terms of the payback period and a much longer term window. MVHR self selects though as you make the building more airtight. Link to comment Share on other sites More sharing options...
G and J Posted June 17 Share Posted June 17 51 minutes ago, Kelvin said: I did something similar but being a bit older the payback period matters slightly less. Therefore I considered it both in terms of the payback period and a much longer term window. MVHR self selects though as you make the building more airtight. Some things like MVHR just get in due to how nice it is to live with it there, like nice sanitary wear or cladding that looks right for the location and design. The latter two do not have a payback financially, except perhaps sale value and I don’t much care how much our executors sell for. MVHR requires airtight therefore that’s in too. Link to comment Share on other sites More sharing options...
