Looking to fit an "extractor fan" to a small bathroom extension. Rental and really nice tenant. 3 kids, lots of bathroom use so some black spotting on the ceiling above the bath. Bathroom window directly above the garden box:
IMG-20200902-WA0008.jpeg.df93301ea916d424fb59aecee7f33933
Access into the roof space above the bathroom is likely doable, through the airing cupboard where the gas boiler is (lucky I'm slim):
20201206_125153
Looking from the hatch to the end wall above the garden box:. There's a smattering of old fluffly insulation between the ceiling joists. As the outside is all brick thinking this must be a cavity wall on the end. Looks like a line of Celcon blocks just above the joists. Not sure how those ceiling joists are "fixed", looks like L brackets rather than proper hangers. I was thinking I might as well put a crawling board up there and maybe re-insulate whilst in there. Going over there at the weekend so will look then.
20201206_125221
Going to get some better internal pictures. Thinking mabe a SELV extract directly above the bath but have to check heights to the ceiling ref Zones. Pretty sure it's all Zone 1 above the bath height wise. Saying that, an inline fan in the loft space would I think negate any requirement for SELV/PELV?
I can fit an isolator above the bathroom door entrance on that grey bit of wall to the left, behind the chandelier. The door in the picture is the airing cupboard door open against the bathroom door:
IMG_20201129_112914888
Rough sketch of the bathroom. There's a shower rail and folding screen the towel rail end. Mulling a single room MVHR unit above the sink exiting out into the "alley", first picture above:
48sar_br_001
Only photos I have:
IMG_20231017_224749516
IMG-20200830-WA0020.jpeg.33b2cb986da84950121496898ae478dd
Greenwood CV2GIP, low background ventilation, easy setup, smart boost when humidity rate of rise is above a given threshold - almost silent.
Mounted in ceiling and duct away, if that's easiest.
Pulls about 2Wh electric.
Normally get them on eBay cheap enough.
My top tip.  Do NOT fit an accessible fan isolator in a rental.  I have known tenants turn them off because they are noisy then complain about the condensation.
I do not believe they are legally necessary (I have asked several times for someone to point me to the reg that says you must fit one and nobody has) but if you really feel you need to fit one, put it up in the loft close to that loft hatch.
Check how air will get into the room to replace what is extracted, you may need to plane a bit off the bottom of the door for instance.
  • Like 2
A Vent Axia MVHR unit here? Would draw the warm, wet air across to it and out the wall?
48sar_br_001a
48sar_br_001a
Not sure about that, it would push new air in to the room and pull air out of room.  Believe that are not the quietist units available, so more likely to get switched off, as annoyance
Went over today and had a look. Definite mould spots :( Need to sort asap really.
Bathroom is nom 9m3.
Height from floor to ceiling is 2170mm. Inside bath to ceiling is 2100mm so Zone 2 all the way to the ceiling above the bath and 600mm past the bath.
20240525_102307
20240525_105309
20240525_102310
20240525_102312
20240525_105301
20240525_102318
Interesting outside, an old air brick blocked up with a very weak mix. There's no matching vent inside though, cavity vent?
20240525_103002
20240525_103022
Edited by Onoff
8 hours ago, Dave Jones said:
The dreaded cranked ceiling. No insulation there and sure enough mould grows.
those cranks should have trickle vents , would 100% fix the issue
Never had an issue until now in about 15 years. Now there's 5 people using the bathroom.
Got any links to this and where the vents should go?
It always comes down to interpretation of localised isolation.
Some define it as within the area it's installed, others count the breaker as such.
Still got to do this so thinking on options and tbh ease of install and maybe future planning:
Option 1:
Simple extractor fan. place directly above the shower end of the bath here (Zone 2):
53745065341_62408d0524_c
Duct through the wall:
50686024713_17df82288f_c
To vent here:
53745387099_3c8a2af6a8_c
Or ducted to a tile vent:
50686024713_17df82288f_ca
53745386869_68e1b3e461_c
With the above, potentially no drilling. No MVHR though.
Option 2:
Vent Axia Lo Carbon MVHR unit, 12V:
Screenshot 2024-05-30 101947
Mounted here, again in Zone 2:
53744135022_81dfcd484d_c
Ducted through the wall to here:
51268803756_232cbdc327_c
Thinking the heat recovery aspect and bringing fresh air in would be good.
Or a combination of the above, or something else...no drilling is appealing.
How about. A "proper" MVHR up in the loft space.
Fresh air intake and warm, wet extract tile vents on the roof, one each end. Warm, wet intake in the bathroom, same place,  above the shower. Fresh air ducted into the lobby ceiling just outside the bathroom?
50659721103_651fa98703_c
Would I need to insulate any ducts?
Edited by Onoff
Or better still as far from bathroom as poss and get plenty of cross ventilation
Not easy. To get a duct to the other side of the kitchen would mean clearing an upstairs bedroom, carpets up etc. Possibly an option for later though. Would have to drill though the wall where the copper pipes go through. Not sure on joist levels etc.
Would my idea of the fresh air duct just outside the bathroom work?
Any links to a good, cheap MVHR unit that would do the one bathroom? Room volume nom 9m3.
