Internal doors requirement
Gone West
18 minutes ago, PeterStarck said:
Is there a requirement for timber internal doors to be fitted in order to obtain a BC completion certificate? These are not fire doors.
Hi Peter - the short answer is to ask your BCO as they will have their own view.
Part E (sound) may be a problem:
Part L (thermal insulation)
This would apply only to doors that open into unheated areas of the building so not likely you'd be wanting to leave those off.
I think it would be OK.
The sound regs are weird. I have to buy special sound proof glass for a fixed glass wall between rooms as it has to meet the same requirement as a wall. Yet, if it was a glass door it would not have to meet any regs as doors let loads of noise through the frames.
2 minutes ago, Simplysimon said:
how does that work when strange people put the toilet and bath in the bedroom behind a 1200ish high wall?
In that situation it would all be considered as the same room rather than separate ones
