Space Race Posted April 30, 2024 Share Posted April 30, 2024 Has anyone used either Core LP Edge or Everedge lawn edging? Which brand did you go with and did it work well? The worst I can think is that the ride on mower might run over the edge from time to time. They sell thicker 2.5mm stuff but this looks to be designed more for larger vehicles and gets expensive quick. We are looking at the basic domestic stuff 1.6mm thick, Cor-ten finish and would be using it to edge (yet to be formed) gravel paths. I'm guessing 100mm height would be plenty. Link to comment Share on other sites More sharing options...
Gone West Posted May 1, 2024 Share Posted May 1, 2024 14 hours ago, Space Race said: Has anyone used either Core LP Edge or Everedge lawn edging? I used Everedge Halestem at our last place and found it very strong and easy to use. I used the deep one for the driveway and low one for the footpaths. It was expensive though. Link to comment Share on other sites More sharing options...
canalsiderenovation Posted May 1, 2024 Share Posted May 1, 2024 We were going to use Core Edge for a gravel path. The anthracite RAL7016 stuff arrived and out of the 4 boxes the two boxes we opened were all damaged (scratches on top edge, paint worn off, dents etc). In the end they collected the two unopened boxes and left us the 2 we had opened to dispose of. We have messed around with thr damaged pieces to see if we can make use of it where it isn't really seen but haven't used it. For curves I think it works better than for straight edges and the corten may be better than the powder coated ral stuff. In the end we used sleepers which was far cheaper and seemed to work better with our straight edges (there are some plants and grasses planted within the path). Link to comment Share on other sites More sharing options...
Space Race Posted May 1, 2024 Author Share Posted May 1, 2024 8 hours ago, Gone West said: I used Everedge Halestem at our last place and found it very strong and easy to use. I used the deep one for the driveway and low one for the footpaths. It was expensive though. Thanks, Had a look at the Halestem which they list as commercial. Its 2mm thick and sold in longer lengths with flexible or rigid options. I'm hoping the 1.6mm version will be more than adequate for our needs because yea, It's pricey stuff. I'm looking at it as should offer a tidy edge and not need replacing anytime soon. Link to comment Share on other sites More sharing options...
Space Race Posted May 1, 2024 Author Share Posted May 1, 2024 7 hours ago, canalsiderenovation said: We were going to use Core Edge for a gravel path. The anthracite RAL7016 stuff arrived and out of the 4 boxes the two boxes we opened were all damaged (scratches on top edge, paint worn off, dents etc). In the end they collected the two unopened boxes and left us the 2 we had opened to dispose of. We have messed around with thr damaged pieces to see if we can make use of it where it isn't really seen but haven't used it. For curves I think it works better than for straight edges and the corten may be better than the powder coated ral stuff. In the end we used sleepers which was far cheaper and seemed to work better with our straight edges (there are some plants and grasses planted within the path). Looks lovely! Yes can imagine the powder coated stuff taking a bashing and soon looking tatty. I noticed the local National Trust property used the cor-ten finish and seemed to work well. Sadly no gardeners around to ask. I'd weighed up using timber but we've so much of the stuff already around the garden I'm looking for less rather than more to maintain. I feel it will be easier to get the level of the core/ever edge set right so we can mow right over the top. Who did you order from and did you choose to keep those two boxes or did they refuse to take back? Link to comment Share on other sites More sharing options...
twice round the block Posted May 2, 2024 Share Posted May 2, 2024 You may get a better deal by contacting some local steel stockholders. Link to comment Share on other sites More sharing options...
canalsiderenovation Posted May 2, 2024 Share Posted May 2, 2024 20 hours ago, Space Race said: Looks lovely! Yes can imagine the powder coated stuff taking a bashing and soon looking tatty. I noticed the local National Trust property used the cor-ten finish and seemed to work well. Sadly no gardeners around to ask. I'd weighed up using timber but we've so much of the stuff already around the garden I'm looking for less rather than more to maintain. I feel it will be easier to get the level of the core/ever edge set right so we can mow right over the top. Who did you order from and did you choose to keep those two boxes or did they refuse to take back? It was Ideal Garden and they offered some Blue Light Discount too. They took back the 2 boxes of unopened ones and they said we could keep the 2 boxes we had opened which were damaged (sent in proof). Link to comment Share on other sites More sharing options...
canalsiderenovation Posted May 2, 2024 Share Posted May 2, 2024 If you want a 5% discount with Ideal Garden this is the code they gave me idealfive Link to comment Share on other sites More sharing options...
Temp Posted May 2, 2024 Share Posted May 2, 2024 I'd design out all edging so the mover can cut right to the edge. Unless you like using a strimmer. Link to comment Share on other sites More sharing options...
Mike Posted May 3, 2024 Share Posted May 3, 2024 On 02/05/2024 at 23:13, Temp said: I'd design out all edging so the mover can cut right to the edge. Me too. Or use bricks set below the level of the lawn. And I'd invest in a robot mower... 1 Link to comment Share on other sites More sharing options...
Space Race Posted May 8, 2024 Author Share Posted May 8, 2024 On 02/05/2024 at 13:46, twice round the block said: You may get a better deal by contacting some local steel stockholders. If it was just a case of buying the plate cor-ten and having them cut it to length I’d agree 100%. They’d need to weld pins to the plate though, Otherwise I’m thumping long lengths of deeper plate into the ground. They’d also need to weld lugs on so I could join each length. Between the time/labour fee and the fact it would probably be an inferior design when all said and done, I’ll stick with the edging stuff. Link to comment Share on other sites More sharing options...
Space Race Posted May 8, 2024 Author Share Posted May 8, 2024 On 02/05/2024 at 14:33, canalsiderenovation said: If you want a 5% discount with Ideal Garden this is the code they gave me idealfive Thanks for the code and info, Good to know they did the right thing by you. We’ve quite a bit to do so I’m still working out final meterage and not settled on the thinner or thicker trade stuff. If the mower bent it out of shape I’d be annoyed. Link to comment Share on other sites More sharing options...
Space Race Posted May 8, 2024 Author Share Posted May 8, 2024 On 03/05/2024 at 22:53, Mike said: Me too. Or use bricks set below the level of the lawn. And I'd invest in a robot mower... Yes the plan is to sink it so top of edging is just under the lowest cut on the mower deck so It can be mown over. No robot mower, Ride on Link to comment Share on other sites More sharing options...
