GGJ Posted April 20, 2024 Posted April 20, 2024 Hi,  Currently building a new build property. We are wondering if we could put a sink behind the toilet in our only downstairs toilet? Unsure if this would pass document m4. Something like this. https://victoriaplum.com/browse/all-toilets/type_Close-coupled-toilets?csi=COMPACT01&gad_source=1&gclid=CjwKCAjwz42xBhB9EiwA48pT72Jha4d4Z2BfqiP5-hUavGmKBUGgah3SdAgJ6MGE6ZVuM8w0tZnzpxoCvVEQAvD_BwE ThanksÂ
nod Posted April 20, 2024 Posted April 20, 2024 Yes Once over BC where pretty keen on DS loo dimensions for disabled access Most of this is now largely ignored with loos squeezed in amazingly tight placesÂ
Russell griffiths Posted April 20, 2024 Posted April 20, 2024 Don’t install something you will hate, just to comply. find a better solution. a mate of mine recessed a small sink 90mm into a stud wall to get the required clearance. remember you only need a square of 750mm in front of the toilet for disabled regs.Â
DevilDamo Posted April 20, 2024 Posted April 20, 2024 51 minutes ago, Russell griffiths said: you only need a square of 750mm Although it’s actually a rectangle, 900mm wide x 750mm deep 😄
Russell griffiths Posted April 20, 2024 Posted April 20, 2024 32 minutes ago, DevilDamo said: Although it’s actually a rectangle, 900mm wide x 750mm deep 😄 What are we all looking at, mines been designed around a 750 square I certainly haven’t got 900 wide clear space.Â
Russell griffiths Posted April 20, 2024 Posted April 20, 2024 49 minutes ago, DevilDamo said: Although it’s actually a rectangle, 900mm wide x 750mm deep 😄 I’ve just re read M4 and you are correct on room size. I’ve been going by some drawing I have see of clear uninterrupted space of 750 square. with the 900 wide I believe the basin can project into that 900 width.Â
DevilDamo Posted April 20, 2024 Posted April 20, 2024 @Russell griffiths Paragraph 1.17c states the basin should not impede the space. Diagram 1.4 on the following page however does show a slight basin encroachment.
ETC Posted April 20, 2024 Posted April 20, 2024 2 hours ago, DevilDamo said: @Russell griffiths Paragraph 1.17c states the basin should not impede the space. Diagram 1.4 on the following page however does show a slight basin encroachment. That’s because the whb can impede on the space as long as its wall hung without floor support or a pedestal - hence not impeding access. 1
