Am I going mad or did I read something on here recently about airtight tundishes? Search function doesn't cpome up with anything. Our UVC is going in now and the chap wants to install one fo these https://www.toolstation.com/osma-hepvo-pp-tundish-adaptor-kit-wt/p98120?store=RJ&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=_dc&pcrid=null&pkw=null&pmt=null&gad_source=1&gclid=CjwKCAjwh4-wBhB3EiwAeJsppLV0sVazuV9u0Aor8J5kX5w_mP1RCZXzZY7-CLSO6EVl1x48HWfYvxoCP0gQAvD_BwE&gclsrc=aw.ds
which doesn't seem too airtight to me.
Can anyone put me out of my misery?
Thanks both, are either of those actually room sealed though? Is that even possible with a tundish?
You are fine with either, as AT tests are a 50pa and not 'hurricane' levels. "As built" tests are done with water sat in traps, so this will be fine.
You must consider that both negative and positive pressures occur, so a 'heave' in either direction will have differing effects; a 'suck' on a waterless trap will happen regardless, but not a 'blow'.
These will only be momentary vs constant, and life goes on (even in a Passsivhaus) ;) Same happens with MVHR, it becomes temporarily imbalanced when wind blows onto the fresh and exhaust.
Worry about something more significant is my advice, after you have reflected on doing the best job possible. :) If you can connect to an internal SVP then I doubt any issue would ever occur.
All plumbing done. You can just about see our tundish behind the new OSO UVC.  The small extension to the consumer unit contains the 240VAC power relays to switch the Immersions and the slab Willis and pump. Everything neat and tidy. Jan is a happy lady. We've also had a couple of deep baths to celebrate.
Still got to tidy the last power lead. The shelf above is my "network rack" 🤣
  • Like 3
Are you running the tank purely from solar / grid electricity, or do you have it connected to an ASHP.
We have planning for a passive house and I was thinking of a Sunamp, but have been put off by all the stories and the price, so am now thinking of an OSO running from solar / off peak grid electricity.
I have an all electric passive house. I use Octopus Agile and schedule the slab and DHW heating to take advantage of best prices. Search for my posts and blog entries for more details.
Edited by TerryE
Facts, not stories ;) :/
Prices for them is now utterly insane.
These got rebranded Thermino to try and shake the troubled relationship, and also Aquafficient. Same box, rebranded.
Saw another of these getting wheeled out of someone’s home a few weeks back, never to return, and an UVC going in; to relieve the owner from their long-suffering negative experience.
Sunamp tried hard to wriggle out of replacing some of these failed units. When the clients sought my technical support, Sunamp then backed down and replaced (supply and fit) for free.
Facts, not stories. ;)
  • Sad 1
What is crazy is that in terms of physics and engineering it would be really easy for a lot of us slightly more IT oriented folk to "roll your own" using the basic approach used in the PV,  but keep it real simple N × PCM cells in a well insulated otherwise passive box with water feed and out.  Use a Willis or other reliable inline heater and basic circulation pump, one-way valves, etc.  so that you can both do flow through and internal recirc for heating, plus the control board that I discussed in my recent Microcontroller based power switching topic (these sell on AliExpress for ~£50 and you can use a python-like language if you want to implement all of the control logic locally); this plus a couple of 20A SSRs.  Keep all of the pump and pipework on the outside so it is easily maintainable, and so you don't need a ticket on advanced laparoscopic plumbing. 🤣
I'd be tempted to do this as a "fun" project except that I don't need this myself now, and I've got other stuff on the TODO list.  Even suggesting it might get me a severe blast of dragon fire from someone very close to me.  Marital harmony is far more important to me. 😇
Edited by TerryE
@Tom, thanks for the heads-up.  I'll double-check the manufacturers datasheet and discuss this with my plumber.  If necessary, I will source a compliant alternative and get him to refit it.
I'd need a double failure that is of both the following for the UVC to risk venting: so I don't view this as an immediate fix needed:
  • A failure of one or both of the tank thermostat switches
  • My CH / DHW control system will only power the Immersion circuits if the tank temperature (taken by a separate digital thermometer next to the tank thermostat) is below a configured set point.  Yes,, these DS18B20s can fail, but I've never had one still respond to a reading request but suddenly start to report a value 30°C lower than previous readings .  Moreover if the top of the tank was nearing boiling then both sensors would have to be miss-reporting.
So on the scale of risk, I am a lot less concerned about this than flying on a 737-MAX 🙃  BTW, here is a brief plot of my HW sensors:Screenshot2024-04-0210_18_23.thumb.png.822890c1bd516106a537553275976cca.png
Edited by TerryE
