something I have thought about for years
why has no one -,to my knowledge made a heated bath  to run off CH  system
It would heat the bathroom when not in use and keep the water warm for that long soak . and also be a towel warmer
seems a simple job
wrap a plastic bath in UFH piping and resin it in postion --job done
 If I were younger i would do it my self with a temp stat onso you can set to dired water temp
Am i missing some major reason why not?
Edited by scottishjohn
Oddly I have been thinking about this for years, I never considered using the bath as a radiator but i looked at spa baths and non of them heated the water, only circulated it so went cold very quickly. That got me thinking of taking water from the bath, heating and returning either as a whirlpool or even falling like a conventional tap … just one of my endless “if I get chance I must do this” lists of engineering tinkering projects.
I don’t think so and would be a nice experiment (shame you have sooo much else to do !).
1 minute ago, ProDave said:
Already been invented.  It's called a "hot tub"
To big to use in a general bathroom, unless they now to small ones so practical to drain water after each use rather than filter
However if you leave the bath water to cool down it will help heat the bathroom 🤷‍♂️
  • Like 2
Why would anyone want to soak in a bath for longer than the usual cooldown time of a standard bath.
I did recently see a range of baths made of a heat retaining acrylic that offered some kind of solution to this perceived problem. Very expensive though.
