Another switch question
Pocster
Another way to test.
Do you have a spare table lamp?
Take the plug off it, put the blue wire in with the neutral in the wago.
Put the brown wire in the other terminal in the switch.
If the switch flicks between the main light and the lamp, then the common is the feed. (the perm live)
Edited by FuerteStu
5 hours ago, Pocster said:
I'm still confused on the no neutral thing (I didn't realise this switch didn't need a neutral ).
With no neutral and the switch off it won't be powered and therefore surely can't report or be controlled via Zigbee?
But if neutral is connected ( where too? ) then it is 'powered' and so acts like a smart switch correctly?
No understand. Switch is neutral free. Destructions show neutral connected to squiggle ( why a squiggle?; what's it meant to represent - not seen that before ). - confusion
hate electrics - so dangerous.. I might send it back
The smart switches which don't require a neutral work by still sending tiny amounts of current to live even when the switch is off (in order to complete the circuit) and use that to charge a capacitor which powers the ZigBee gubbins.
