dpmiller Posted February 9, 2024 Share Posted February 9, 2024 the +P version of the Solido Smart that we installed is a single tank solution with a built-in dosing system for Polyaluminium chloride https://www.premiertechaqua.com/en-gb/wastewater-treatment/solido-smart-p-phosphorus-removal#product-description 1 Link to comment Share on other sites More sharing options...
saveasteading Posted February 9, 2024 Share Posted February 9, 2024 6 minutes ago, dpmiller said: the +P version of the Solido Smart Sounds like the answer. @Amateur bob can at least work on this assumption while the others catch up. Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 10 hours ago, saveasteading said: Can the output of both tanks be piped to a single P treatment installation? I'm wondering if the planners have heard of the klargester phosphate removal equipment and assumed this was a digester too. But no, from klargester or Marsh and perhaps the others , it is an extra thing. no unfortunately the two tanks will be on different farms, ahh i see, wonder how much extra its going to cost, the standard klargester ba claims to reduce photspate to the required level but its £4300 Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 1 hour ago, dpmiller said: the +P version of the Solido Smart that we installed is a single tank solution with a built-in dosing system for Polyaluminium chloride https://www.premiertechaqua.com/en-gb/wastewater-treatment/solido-smart-p-phosphorus-removal#product-description thanks ive had a look i assume it does everything else the other bio disc plants too plus the phosphate stripping? what sort of price range if you dont mind me asking Link to comment Share on other sites More sharing options...
dpmiller Posted February 9, 2024 Share Posted February 9, 2024 2 minutes ago, Amateur bob said: thanks ive had a look i assume it does everything else the other bio disc plants too plus the phosphate stripping? what sort of price range if you dont mind me asking I have no idea. You could always try asking them? Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 ive emailed graf 2 one tank supplier he says phosphate is the same as nitrate reading NH4 and they can get down to 0.5mg/l Link to comment Share on other sites More sharing options...
saveasteading Posted February 9, 2024 Share Posted February 9, 2024 40 minutes ago, dpmiller said: I have no idea. You could always try asking them? I googled it. @Amateur bobcan too. Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 12 minutes ago, saveasteading said: I googled it. @Amateur bobcan too. https://www.owlshall.co.uk/sewage-treatment/sewage-treatment-plants/1-4-bedroom/premier-tech-rewatec-solido-smart-2-8-person/ this looks like a feasable option Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 the only concern i have is noone else has mentioned it so its a bit of an unknown quantity Link to comment Share on other sites More sharing options...
crispy_wafer Posted February 9, 2024 Share Posted February 9, 2024 (edited) 7 minutes ago, Amateur bob said: https://www.owlshall.co.uk/sewage-treatment/sewage-treatment-plants/1-4-bedroom/premier-tech-rewatec-solido-smart-2-8-person/ this looks like a feasable option That's what I installed last year. Pumped version though. Not used in anger yet. Edited February 9, 2024 by crispy_wafer Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 2 minutes ago, crispy_wafer said: That's what I installed last year. Pumped version though. Not used in anger yet. did you install it yourself? why not used yet if you dont mind me asking Link to comment Share on other sites More sharing options...
crispy_wafer Posted February 9, 2024 Share Posted February 9, 2024 Just now, Amateur bob said: did you install it yourself? why not used yet if you dont mind me asking yes, installed by myself. Haven't moved into my build yet is the main reason. Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 2 hours ago, crispy_wafer said: yes, installed by myself. Haven't moved into my build yet is the main reason. ah i see, it does the whole job full sewage treatment as well as phosphate stripping? ive emailed waiting to hear back Link to comment Share on other sites More sharing options...
dpmiller Posted February 9, 2024 Share Posted February 9, 2024 ^ that's not the Phosphate version, you're looking for the +P... 1 Link to comment Share on other sites More sharing options...
dpmiller Posted February 9, 2024 Share Posted February 9, 2024 I've attached a document on phosphorus reduction, and PremierTech are aware of this thread following me logging in to download it. Further infos may then follow. WIJ_removal_of_phosphorus_in_off_mains_wastewater_treatment_UK-EN.pdf Link to comment Share on other sites More sharing options...
saveasteading Posted February 9, 2024 Share Posted February 9, 2024 A thought. No more than that: P is a fertiliser and helps plants to grow. That's the problem in this case. Reed beds convert effluent into plants. Is a reed bed an option? Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 48 minutes ago, saveasteading said: A thought. No more than that: P is a fertiliser and helps plants to grow. That's the problem in this case. Reed beds convert effluent into plants. Is a reed bed an option? instead of a sewage treatment plant? is that allowed in some areas? Link to comment Share on other sites More sharing options...
Amateur bob Posted February 9, 2024 Author Share Posted February 9, 2024 3 hours ago, dpmiller said: I've attached a document on phosphorus reduction, and PremierTech are aware of this thread following me logging in to download it. Further infos may then follow. WIJ_removal_of_phosphorus_in_off_mains_wastewater_treatment_UK-EN.pdf 867 kB · 3 downloads thanks ill have a read Link to comment Share on other sites More sharing options...
saveasteading Posted February 9, 2024 Share Posted February 9, 2024 8 minutes ago, Amateur bob said: that allowed in some areas? It's certainly in the building regulaions as an option. Space is the usual reason against it. . But for planning and proven P levels I've no idea. Link to comment Share on other sites More sharing options...
Amateur bob Posted February 10, 2024 Author Share Posted February 10, 2024 15 hours ago, saveasteading said: It's certainly in the building regulaions as an option. Space is the usual reason against it. . But for planning and proven P levels I've no idea. im on a farm so plenty space in fields, is it just a big hole and plant some reeds? Link to comment Share on other sites More sharing options...
saveasteading Posted February 10, 2024 Share Posted February 10, 2024 1 hour ago, Amateur bob said: just a big hole and plant some reeds? It is a snaking channel. Look at the building regulations for drainage. Enjoy! Link to comment Share on other sites More sharing options...
