Roger440 Posted Friday at 23:14 Posted Friday at 23:14 On 02/01/2026 at 21:34, Iceverge said: I think Aereco had the original design. As I understood it it's just a strip of nylon that expands and contracts with humidity. 20Pa really isn't that much. 100000Pa is 1 Bar or about 14psi. Thanks. All the blurb i can fins suggests there needs to be a fan somewhere, you a PIV for them to work. But it seems they are a mystery product, theres just no info beyond the basic website description. Im attracted to the concept as, essentially theres nothing to go wrong, and doesnt use any power. Which seems too good to be true. And we all know what that normally means!
JohnMo Posted Saturday at 08:46 Posted Saturday at 08:46 12 hours ago, Roger440 said: Its far from clear how these work. Google not much help either. What causes the air to move when they are open, as it says you need 20ps air pressure difference There effectively a piece of string, but the string expands and contracts with changes in humidity - it senses room humidity it changes length as the humidity increases to open the vent more. You to have them coupled with MEV or dMEV fans in wet rooms. If these boost automatically, you get a system that self compensates for changes in room habitation etc. So example everyone in lounge in evening, vents in lounge window open, but rest of house vents go to min position, fans draw air through house taking most air from lounge. Everyone goes to bed, lounge vents close and bedroom vents start to open etc
Roger440 Posted Saturday at 09:17 Posted Saturday at 09:17 27 minutes ago, JohnMo said: There effectively a piece of string, but the string expands and contracts with changes in humidity - it senses room humidity it changes length as the humidity increases to open the vent more. You to have them coupled with MEV or dMEV fans in wet rooms. If these boost automatically, you get a system that self compensates for changes in room habitation etc. So example everyone in lounge in evening, vents in lounge window open, but rest of house vents go to min position, fans draw air through house taking most air from lounge. Everyone goes to bed, lounge vents close and bedroom vents start to open etc Thanks. That makes sense. So, as i suspected there still needs to be a mechanical fan somewhere. Interesting though. Until i see where i get to with air tightness, cant really make any decisions.
JohnMo Posted Saturday at 09:28 Posted Saturday at 09:28 8 minutes ago, Roger440 said: Until i see where i get to with air tightness, cant really make any decisions. In Scotland air tightness better than 3.0, balance inlet outlet ventilation mandatory, so MVHR. 3 to 5 MEV or dMEV (with trickle vents), after that whatever fancy passive vent intermittent fans etc, all with trickle vents. 1
mickeych Posted Saturday at 10:46 Posted Saturday at 10:46 12 hours ago, G and J said: Do you use the fancoils much? Not really. We leave them on auto so if the temperatures drop in the upstairs bedrooms they cut in which is very rare. We had some teething issues in the summer getting them to work effectively, but once they were properly sealed into the ductwork they worked a treat reducing the temperature in the bedrooms to 18 from 28 very easily. They are currently set to run at a fairly low speed to not be intrusive and have not needed to boost them so they are doing what we designed them to do.
saveasteading Posted Saturday at 11:11 Posted Saturday at 11:11 24 minutes ago, mickeych said: reducing the temperature in the bedrooms to 18 from 28 very easily Windows do that. 1
mickeych Posted 20 hours ago Posted 20 hours ago (edited) On 03/01/2026 at 11:11, saveasteading said: Windows do that. No they don't when the outside temperature is 28 😉 Edited 20 hours ago by mickeych
G and J Posted 15 hours ago Posted 15 hours ago On 03/01/2026 at 10:46, mickeych said: Not really. We leave them on auto so if the temperatures drop in the upstairs bedrooms they cut in which is very rare. We had some teething issues in the summer getting them to work effectively, but once they were properly sealed into the ductwork they worked a treat reducing the temperature in the bedrooms to 18 from 28 very easily. They are currently set to run at a fairly low speed to not be intrusive and have not needed to boost them so they are doing what we designed them to do. Forgive the interrogation but… Are your fancoils on their own zone or together with your UFH? I ask as we are installing our main bedroom fancoil as part of the single zone, but with the ability to zone it off later if needed.
