Adam2 Posted November 17, 2023 Posted November 17, 2023 I've laid all the full tiles on my terrace (on pedestals) and now about to attack the edges - the tiles are 20mm porcelain 600x600. About 30 tiles to cut. I'd like to get a non or very minimally chipped top edge - what should I use for this? I understand the cutting disc is really important and I need a wet cutter.  Would a simple table like this https://www.toolstation.com/vitrex-power-pro-750w-wet-tile-cutter/p82003?store=LQ&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed  With a decent blade like this https://pureadhesion.co.uk/rubi-porcelain-tile-diamond-rim-machine-blade-cpc-180mm-30955/  be up to the job?  Or do I need a big machine like this  https://tools4trade.co.uk/products/excel-1250mm-wet-tile-cutter-bridge-saw-240v-1200w?variant=42311376273605¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&srsltid=AfmBOoo12F815X3zguW7QZLU7TscCY51PE_vmPOLbFPYaUAjtbeUW5wJGE4  which maybe I should rent? I guess a blade that comes down into the tile face may mean a cleaner cut?  cheers for info Â
Mr Punter Posted November 17, 2023 Posted November 17, 2023 @Pocster had / has a Dewalt tile saw for sale. I have used the same model and they are very good.
nod Posted November 17, 2023 Posted November 17, 2023 I use an angle grinder with a turbo blade on most things Ive a couple of Robi zero dust cutters Which are handy if your in an enclosed area and several floors up But a bit big for moving around 1
saveasteading Posted November 17, 2023 Posted November 17, 2023 I was surprised how well a cheap electric tile saw worked. I thought as long as it survived one project it was worth it. Kitchen and shower room, floor and walls  Only 12mm tiles, but I don't see why it wouldn't work for 20mm apart from patience failing and pushing too hard that it strains the motor. Didn't even need to change the disc. £50 was worth it.  I've never used a professional one, so can't compare. 1
Gone West Posted November 17, 2023 Posted November 17, 2023 I bought a 620mm wet bridge saw for around £150 back in 2010. I did all my floor tiles, roof tiles and sandstone paving with it, and at the end, the bridge bearings were knackered so I gave it away. Used several blades but always got clean cuts with no chips. 1
Adam2 Posted November 20, 2023 Author Posted November 20, 2023 Thanks all - in the end I found a Rubi table saw for a bargain locally so have that - did a test and even with the blade left in it it cuts cleanly through the 20mm tiles 🙂 Only issue is the amount of noise this is going to make, my neighbours probably thought I'd finished making a racket!
nod Posted November 20, 2023 Posted November 20, 2023 4 hours ago, Adam2 said: Thanks all - in the end I found a Rubi table saw for a bargain locally so have that - did a test and even with the blade left in it it cuts cleanly through the 20mm tiles 🙂 Only issue is the amount of noise this is going to make, my neighbours probably thought I'd finished making a racket! If it’s a zero dust table you can do all your cutting inside the house with the windows closedÂ
Adam2 Posted November 21, 2023 Author Posted November 21, 2023 20 hours ago, nod said: zero dust table well no dust but plenty of water coming through the table when cutting - it's cold out neighbours can close the windows
