Oak Mantel
MortarThePoint
Our fireplace has a 6ft opening with a 140(w) X 215(h) concrete lintel over. I'd like to dress this in Oak and there are places selling 3-4 year seasoned for ££ and others selling partially seasoned for £. I'm wondering if well seasoned is a red herring as it will always need to adjust to its new environment.
My hope is to attach it to the concrete lintel and then plaster around it (11mm Hardwall plus 2-3mm MultiFinish). What are my chances of the oak not shifting and cracking the plaster? @nod do you ever do this and do you have any tips?
You have absolutely zero chance the oak won’t move and the plaster won’t crack.
Can you build it in, in a way that the plaster does not but up to it, either a stop bead or mount the oak forward and the plaster sits behind somehow.
Oak frame houses and plaster were always a problem, so they changed how they are boarded and the plasternow goes behind the oak so they are free to both move independently.
I would look  at this for maybe a solution.
I actually used Oak as the lintel (given to me by my builder as he had it spare) even tho it was well seasoned it shrank about 5mm across its 200mm making it loose in the brickwork (bricks didn’t fall down) packed  it with 5mm oak wedges underneath to keep it tight, stopped shrinking after 2 years.
I definitely wouldn’t use hardwall Sand-lime would be more suitable As there is very little shrinkage
We planned to build oak in last time and the fitter said he wouldn’t certify
@MortarThePoint
Here are a couple of images showing how our oak beam was fitted. When installed, it came with two large "bolt" type "pins" protruding, which were then drilled into the concrete lintel.
The surrounding area was then plaster boarded. I have to say in the past 5 years we have not suffered any shrinkage or cracking or either the beam or plaster.
The beam was sourced and fitted by the approved stove fitter!
Edited by Redoctober
Tidy up
