IanMcP Posted November 9, 2023 Posted November 9, 2023 (edited) house build is Nudura. I have 4 areas between windows that I want to clad. Remaining external is render. The effect I want is vertical slatted. Think 2x1 with a 10mm gap I I I I I I … like this 🙂 my question is how best , simply to construct this. for simplicity I’m thinking : - 3 horizontal , top middle bottom , battens. - black breather membrane across area. Black to hide the lovely blue wall. - vertical slats , C24 painted. With 5/10mm space , which would then be black. Any issues here ? pointers on best membrane welcome ! ta. oh and nobody has bought my spare blocks yet !?! 🤷🏻♂️ Edited November 9, 2023 by IanMcP
Chanmenie Posted November 9, 2023 Posted November 9, 2023 (edited) Do you need a membrane @IanMcP , I have been looking at cladding for my gable ends, research has told me EPS does not need a membrane, unless you’re doing it just to hide the blue Nudura blocks. I’m considering using Hardie VL Plank which won’t have gaps so won’t need to worry about hiding my white Beco Blocks Edited November 9, 2023 by Chanmenie
IanMcP Posted November 9, 2023 Author Posted November 9, 2023 Membrane purely cosmetic to cover the blue in the gap. But if it isn’t breathable the battens behind won’t get to dry out ?
Russell griffiths Posted November 9, 2023 Posted November 9, 2023 (edited) What’s the height? 3 battens won’t be enough. How do you stop the breather membrane getting all flappy. ?? How do you stop insects eating the breather membrane. ?? On the whole your idea needs far more thought I would get it all rendered, but the bit that is to be clad, just do the base coat and mesh, paint this Matt black, then fit the battens and cladding. Just my first thoughts. Edited November 9, 2023 by Russell griffiths 1
IanMcP Posted November 9, 2023 Author Posted November 9, 2023 All valid @Russell griffiths hence me throwing it out there. 👍 like to idea of render then simply clad over that. I have part grey render so would do that to match windows then timber over. horizontal battens would be as many needed. Say 600 spread ?
Russell griffiths Posted November 9, 2023 Posted November 9, 2023 Check with the cladding manufactures fixings normally 600 any wider and I think you will get wobbly cladding look.
Nick Laslett Posted November 9, 2023 Posted November 9, 2023 Lots of useful info here: https://www.tdca.org.uk/timber-cladding/cladding-fixings/ The Timber Cladding Handbook covers a lot of this topic. This supplier also has lots of useful info to download, which is applicable to other products. https://www.mbmspeciality.co.uk/products/thermowood/lunawood/ I don’t recommend this approach as Cedral/Hardie planks are good enough. But I went with Ash Thermowood. It has all the issues of normal timber cladding, plus you can’t use nails!! Only advantages are dimensional stability and greater resistance to fungus, insects, etc. Go with artificial, unless you really can’t bear it.
FM2015 Posted November 10, 2023 Posted November 10, 2023 You could look at a paint on membrane type product. Non solvent and dries black. There's a few about. Could paint your battens too for added protection. Stainless screws, obviously a given.
