Square Feet Posted June 14 Author Posted June 14 I've recently found this guy who does EV battery installs in domestic projects. I'm going to do the same on my build so it's very interesting to see how he does it, which EV batteries work best and how much it all costs. He is English, from Shrewsbury or somewhere like that I think so it's helpful for me that he is speaking in pounds and pence and UK regs.
JohnMo Posted June 14 Posted June 14 I would place it well away from house, not sure how your house insurance would react to a house fire caused by self install car battery to house using YouTube instructions? Is the price savings even worth the effort these days, plenty of cheap battery setups available.
Square Feet Posted June 14 Author Posted June 14 6 minutes ago, JohnMo said: I would place it well away from house, not sure how your house insurance would react to a house fire caused by self install car battery to house using YouTube instructions? Is the price savings even worth the effort these days, plenty of cheap battery setups available. Yeah mine is going to be in a separate building. 1
Square Feet Posted June 22 Author Posted June 22 I've been watching this playlist by Buildhubber @CJO on how they prepped and built their passive slab using Isoquick. It's really well put together and very well explained. The methods may not be universal but I have a lot more confidence that I understand the process and how to go about it now. (I tried to link to the whole playlist but it just takes you straight to the most recent video which is annoying. Here's the first one of three - I'll link to the others individually below).
Gus Potter Posted June 22 Posted June 22 (edited) 2 hours ago, Square Feet said: I've been watching this playlist by Buildhubber These type of videos are always good to watch, informative. As a designer I see stuff that makes my hair curl a bit, I've not got that much left mind. Their rebar is a bit of a disaster for example. Anyway I'm not going to point out where they have made life hard for themselves and by the looks of things paid for something that has not actually been delivered on site. It looks like they are happy folk so leave it at that. This is key to good design in the self build market is.. keep it simple so you don't end up paying for something that does not serve it's intended purpose as a result of it not getting delivered on site. The positioning of their UFH pipes at the underside of the structural slab is "innovative". I would tend to put the UFH pipe towards the top of the slab as it reduces the response time not least. The Isoquick is one effective solution. But if you are doing a full hands on self build then I would look at other options where you use standard insulation, be that PIR or EPS. As a kind of hands on SE I like the flexibility it gives you on site, especially around openings or where you may have high point or line loads. Here, if hands on self build we would look at cash flow, maybe it's best to pay as little as you can for the materials that are easily sourced from a local merchant as your labour is "freeish"? "Raft" type foundations are fascinating things to design..there are many permutations, some are generically described on BH as rafts.. but they are actually not. From time to time I'll sit down with a Client and design from the ground up and explain in terms they can understand what I'm doing as a designer and it gives them a feel for the ground and how the structure works from there up. This allows them to make informed choices. The decisions you make on the ground, foundations translate all the way up though the structure. I really enjoy this process as it triggers the enjoyment I get from teaching. You see a light bulb coming on in the Clients heads where they see the jigsaw coming together, I see their confidence building. It doesn't matter if the Client has never done a self build before or if they have technical knowledge. I always start with a "refresher course" as it helps the Client and I explore our technical ability, our strong and weak points. The door swings both ways here. I don't know everything! As I've said before. If you set up your build well and find the right designer for you it is hugely rewarding for both. Of course there will always be issues on site.. hiccups all the way to what seems like a disaster! .. but if you plan well you can often avoid the worst. Even if something "bad" does happen then if you have spent time with a helpful designer then you can phone a friend and also use the skills they have taught you to find a work around. @Square Feet Keep researching! Edited June 22 by Gus Potter 2
JohnMo Posted June 23 Posted June 23 We explored passive raft type, but went for something ground workers around us are used to doing. Zero novelty, zero learning. Labour becomes cheap they don't need much steering in the right direction. We went ground bearing slab, all bog standard structural engineer stuff. Then paid attention to eliminate any cold bridges and had that added into the design by the structural engineer. Just keep it simple, do what is normal for your area, then pay attention to detail, but make sure you understand the heat flows, making sure any cross section, in any direction, has no gaps (cold bridges). YouTube videos can be good, I watch loads, but plenty are utter nonsense. But a better source of information is Passivhaus. 1
Gone West Posted June 23 Posted June 23 10 hours ago, Square Feet said: how they prepped and built their passive slab using Isoquick We were the first Isoquick installation in England, sixteen years ago. The Isoquick part was very straightforward, unfortunately the concrete laying didn't go to plan. 2
Square Feet Posted June 24 Author Posted June 24 On 22/06/2026 at 22:56, Gus Potter said: @Square Feet Keep researching! Don't worry Gus - I am just window shopping at the moment - any decisions on things like this will be taken after getting your advice of course, but - when we discuss it now I will have a better idea what you mean and something to compare it to. Every day's a school day.
-rick- Posted June 24 Posted June 24 On 22/06/2026 at 22:56, Gus Potter said: The positioning of their UFH pipes at the underside of the structural slab is "innovative". I would tend to put the UFH pipe towards the top of the slab as it reduces the response time not least. This has been quite commonly done by people on this forum building highly insulated homes. Idea being you design the home to be a stable temperature and the slow response can be used to your advantage by loading in the heat when it's cheapest and letting the floor buffer the output over the day. Putting coils anywhere in a 150mm+ slab is not going to lead to a fast response anyway (need a insulated screed for that) so burying the pipes lower also minimises the chance of damage later and debatably is easier to install. I can't remember all the arguments for this method made by others off-hand, but do know that after reading thoroughly here I'd been persuaded that I'd likely go that way if/when I come do this. (dependent on installation sequencing). 1
Gus Potter Posted June 24 Posted June 24 (edited) 9 hours ago, -rick- said: This has been quite commonly done by people on this forum building highly insulated homes. Idea being you design the home to be a stable temperature and the slow response can be used to your advantage by loading in the heat when it's cheapest and letting the floor buffer the output over the day. Putting coils anywhere in a 150mm+ slab is not going to lead to a fast response anyway (need a insulated screed for that) so burying the pipes lower also minimises the chance of damage later and debatably is easier to install. I can't remember all the arguments for this method made by others off-hand, but do know that after reading thoroughly here I'd been persuaded that I'd likely go that way if/when I come do this. (dependent on installation sequencing). Hi Rick. You make good points here. A common thing on BH is that folk split design into packages to try and get a handle on the build cost. But this is not the most efficient way to design or execute a design. Design needs to be holistic.. and that is the dilemma that Build Hubbers often face. You'll often see folk on BH discussing insulated raft concrete structural slabs (passive or otherwise) thickness and worrying about the slab say being 50mm thicker. It understandable as no one takes the time to explain the cost benefit of using a thicker concrete slab. As an SE and designer when considering a self build and the constraints about say getting a builder that can follow a drawing I often start by selecting say a 200 - 250mm slab. What I'm often doing here is to avoid local thickening of the slab, different levels of sub base, doing funny stuff with the DPC / possibly gas membranes etc where we may have line loads from internal load bearing walls. I always start with the simplest and stupid design option, even though this may seem counter intuitive. To get best thermal performance we want to see if we can have an even thickness of slab as it gives us the best chance on site of actually delivering what we have designed. Good thermal performance requires good workmanship and attention to detail also.. so let's not make the workmanship element too hard? Now if we opt for a slightly thicker concrete slab it lets the SE add rebar easily in the bottom of the slab to take the line and point loads from say internal load bearing walls. But if we then put the UFH pipes in the same bottom slab zone is impacts on the rebar bond strength and makes it hard to install the UFH pipes. It all gets really congested and that leads to you paying for something that is not likely to get delivered on site. That leads to disputes.. which we want to avoid.. self building should be fun! One reason I start out with the simple stupid option is that it lets the Client see and opt for it, yes there is some compromise.. but then we look at more complex stuff and compare costs as we have the simple option as a benchmark. But to finish your observation is correct.. ish. But I know from experience that having designed and installed UFH heating in my own houses for decades is that if you put the UFH pipes in the top of the slab the response time is less than if the UFH pipes are in the bottom. In some ways it's a moot point when you look at all the other practical plus points that go with buildability. The easier it is to build the less the cost. But being easy to build, if well thought out does not mean we need to compromise on thermal performance or quality for example. Edited June 24 by Gus Potter 2
saveasteading Posted June 25 Posted June 25 9 hours ago, Gus Potter said: Design needs to be holistic That's fundamental to me. Followed by the kiss principle because most (?) trades are not as skilled as they think they are, and can't handle anything out of the ordinary. I also like the principle of one trade at a time and gradually working to more accuracy as the building emerges....I mean look for total accuracy but expect less. Thus I prefer to avoid ufh pipes in a structural slab. Get the heavies to pour the slab, then insulate and screed much later.
ToughButterCup Posted June 25 Posted June 25 11 minutes ago, saveasteading said: ......trades [...] can't handle anything out of the ordinary... Thats the one big lesson for self building 1
Square Feet Posted June 25 Author Posted June 25 10 hours ago, Gus Potter said: Good thermal performance requires good workmanship and attention to detail also.. so let's not make the workmanship element too hard? That was what I liked about these videos - the attention to detail. They got their sub base to within =/-5mm of level across an odd-shaped site and it was interesting to see how they did that. Just as an example of how it can be done by two fit strong young people with youth on their side. So probably nothing there that I can take away really.
-rick- Posted June 25 Posted June 25 1 hour ago, saveasteading said: Followed by the kiss principle because most (?) trades are not as skilled as they think they are, and can't handle anything out of the ordinary. Definitely an important point (which was the caveat in my previous statement though not expressed as such). I'm always thinking about keeping the details to something I would be able to do myself. If/when it comes to the build I don't intend to do everything (though a substantial part) but by keeping that in mind I want to keep the options open depending on contractors and skills available when it comes to it. Having said that, laying UFH is very DIYable and likely to lead to a better result than an uncaring contractor. Installing rebar on the other hand is more challenging and have a contractor come in with lots of heavy rebar after the UFH is laid would be a reason not to do it that way. 11 hours ago, Gus Potter said: As an SE and designer when considering a self build and the constraints about say getting a builder that can follow a drawing I often start by selecting say a 200 - 250mm slab. What I'm often doing here is to avoid local thickening of the slab, different levels of sub base, doing funny stuff with the DPC / possibly gas membranes etc where we may have line loads from internal load bearing walls. This is a good point, I've tended to lean the other way (less concrete/rebar if possible) in order to keep the embedded carbon down. Though a thicker simpler slab is likely easier. 2
saveasteading Posted June 25 Posted June 25 Could I do it? Is a good test. I might be very slow, but if I could do it then so can they, faster and sometimes better... especially if watched.
Gus Potter Posted June 26 Posted June 26 (edited) On 25/06/2026 at 09:11, saveasteading said: Thus I prefer to avoid ufh pipes in a structural slab. Get the heavies to pour the slab, then insulate and screed much later. There are so many different options with this stuff. Much depends on how you want to set up the design from the ground up. For self building I would advocate; identifying your skills and the time you have to learn, cost curve/ cash flow and programme. Also the time you have to do things yourself and if you don't mind "just giving some stuff a go". For me as a designer I love seeing the ideas folk have on BH and many bring specialist knowledge (or just whacky ideas) that they have gained elsewhere to the table. This makes my job great fun as a designer.. working out how you realise folks ideas, turn them into something buildable that won't fall down. On 25/06/2026 at 10:26, Square Feet said: They got their sub base to within =/-5mm of level across an odd-shaped site and it was interesting to see how they did that. Just as an example of how it can be done by two fit strong young people with youth on their side. So probably nothing there that I can take away really. But at least you have identified what you may prefer not to do! Nothing lost then as good design is just as much about ruling options out than in. On 25/06/2026 at 11:03, -rick- said: his is a good point, I've tended to lean the other way (less concrete/rebar if possible) in order to keep the embedded carbon down. Though a thicker simpler slab is likely easier. Here we can split hairs.. for a bit of fun, it's really a subjective argument. You can't have a thin slab and less rebar, the two just don't go together. At the extreme you have either one or the other structurally. Putting the UFH in the structural slab can avoid the need for a screed. Later installing the screed requires more wagon journeys and so on. At the end of the day you may want a 65mm average depth screed, which is non structural. But if I make the structural slab 30 - 50mm thicker it goes a long way towards the carbon neutral equation. That said, I often say good design is holistic. If you are proposing large format ceramic tiles on the structural slab then I think the screed option is better as it gives you a better chance of sorting door thresholds for example and avoids the use of self levelling compounds and the frustration that comes with that. In my latest own house I have the UFH in the structural slab. But I have engineered timber floors which are much more forgiving if the levels are a bit off. There is a rough rule of thumb that the "basic structure" comprises 10 - 15% of the over all cost of the project. But what is essential is that the basic structure is set up in such a way so as to avoid later and costly build problems. For example fit up, material tolerances and so on. This is why it so important to design holistically. To do this is not as hard as later trying to sort out problems later in the build. The real up side is that you get to do stuff on paper before spending any real money. Your confidence builds before you start work on site. Edited June 26 by Gus Potter 2
Gus Potter Posted June 26 Posted June 26 5 minutes ago, Gus Potter said: Your confidence builds before you start work on site. To add a bit to this. it's not just your confidence it's mine also. I need to be confident we have a good, buildable and well thought out design. If not things will go wrong on site, or later latent defects will materialise in the design and that reflects badly on my business. 1
-rick- Posted June 27 Posted June 27 13 hours ago, Gus Potter said: Here we can split hairs.. for a bit of fun, it's really a subjective argument. You can't have a thin slab and less rebar, the two just don't go together. At the extreme you have either one or the other structurally. sure, but yet if you look at what’s offered commercially as solutions to insulated rafts. You have some companies (eg kore) offering standard starting points of 100mm slabs with thickened sections and relatively limited rebar vs isoquick with 250mm single thickness slabs with tons of rebar. Afaik for equivalent ground conditions. Now it may well be that isoquick is designed to allow for a more diverse range of ground conditions ‘off the shelf’ vs kore that would get bulkier in some. But if you go with isoquick for ground conditions that work with the standard kore then you’ve used significantly more concrete and steel for the same (and labour to install the rebar) than kore. 13 hours ago, Gus Potter said: Putting the UFH in the structural slab can avoid the need for a screed. Later installing the screed requires more wagon journeys and so on. absolutely 13 hours ago, Gus Potter said: That said, I often say good design is holistic. If you are proposing large format ceramic tiles on the structural slab then I think the screed option is better as it gives you a better chance of sorting door thresholds for example and avoids the use of self levelling compounds and the frustration that comes with that. interesting point. Noted 13 hours ago, Gus Potter said: There is a rough rule of thumb that the "basic structure" comprises 10 - 15% of the over all cost of the project. But what is essential is that the basic structure is set up in such a way so as to avoid later and costly build problems. For example fit up, material tolerances and so on. agreed. One of the reasons I lean towards paying others to get to level slab and doing much more myself after that point. 13 hours ago, Gus Potter said: This is why it so important to design holistically. To do this is not as hard as later trying to sort out problems later in the build. The real up side is that you get to do stuff on paper before spending any real money. Your confidence builds before you start work on site. Yep. Seems like the easiest way to get in a mess with building projects is to design as you go/start with rough detail and plan to flesh out as you get to each stage. Unfortunately seems like an all to common approach for people. 1
saveasteading Posted June 27 Posted June 27 7 hours ago, -rick- said: installing the screed requires more wagon journeys and so on. Not necessarily. It all depends on the ground, the design strategy and the resulting slab thickness. There is no one answer. But my instinct on good ground is screed (with heating pipes) over pir over concrete over stone. Tolerances getting tighter all the way. No groundworkers walking on pir or ufh pipes. The weakest part of that construction is the pir and the slab is obv much stronger but taking little load. I don't really know isoquick but feel it is a relatively conservative design, reducing risk for the novice but at some (considerable?) capital cost. Structural rafts on poor ground are a different matter. I can't recall ever using one, preferring beam and block (or plank) instead of stone and slab.
Gus Potter Posted June 29 Posted June 29 On 27/06/2026 at 18:04, saveasteading said: There is no one answer. Very much agree here. Most self builds are unique, start with a basic design that has a fighting chance of working and then adapt for specific design.. that is the fun part. On 27/06/2026 at 18:04, saveasteading said: Structural rafts on poor ground are a different matter. They are indeed. I've done some adjacent to mine shafts with highly contaminated land, one on really soft sand on an airfield up near Nairn in Scotland, one daft one next to a canal in the Norfolk Broads, they really are bespoke animals. Down Norfolk way I did one where we basically "floated" a single storey building on the peat. This leans towards folk doing straw bale or oak frames with wattle and daub as it really maintains the design and environmental ethos. This takes a leap of faith and careful design of the drainage and service connections to a building that can rise and fall quite a bit. The building itself needs to be pretty flexible. The movement can be huge! But these are worth a shot when the piling option may be expensive. Piles in deep peat also need to be designed for bending as the wind pushing on the side of the house needs to be transferred to the competent soil deep down. On 27/06/2026 at 18:04, saveasteading said: I don't really know isoquick but feel it is a relatively conservative design, reducing risk for the novice but at some (considerable?) capital cost I don't think it's conservative per say, we know the mechanical properties of their insulation. Things can start to go wrong it there is a late design change, poor design coordination between the different work packages or unexpected ground conditions, or most common a setting out error. That is why I want to understand the Client's capability, how much hands on control they have. Using PIR insulation sheets and fitting them together on site allows for flexibility as you go, maybe you need to pay for a bit more labour but at times the risk / economics stack up. Some Clients want fast and quick and are happy to take the risk that something minor can throw a spanner in the works. They rely on the Contractor to sort it out.. but then a dispute can arise. 1
saveasteading Posted June 29 Posted June 29 1 hour ago, Gus Potter said: floated" a single storey building on the peat straw bale or oak frames with wattle and daub Comparing this to the concurrent discussion on insurance of non-standard construction.... how many online questionnaires will have this option to tick?
Gus Potter Posted June 29 Posted June 29 1 hour ago, saveasteading said: Comparing this to the concurrent discussion on insurance of non-standard construction.... how many online questionnaires will have this option to tick? Absolutely none. In simplistic terms I design it as the SE, take that liability on, check with my insurer in case they want to add a bit of an uplift to be compatible with the warranty providers reasonable terms. The warranty provider runs my design by their Engineers. They analyse the risk, add in a bit of a hassle factor for them and make their premium offer. You can pretty much insure anything. It often called gambling, it's just on houses rather than the horses. 1
saveasteading Posted June 30 Posted June 30 7 hours ago, Gus Potter said: It often called gambling I wonder, with many insurances being via comparison sites and tick list questionnaires, how often people tick the nearest description to theirs. This could result in a claim being refused. Insurance companies vary with some being fair and others being cynical claim deniers. I overheard a manager of one insurer (it happens that I'm seeing their name all over the place at present) saying proudly that they are by far the "most successful" in avoiding claim payouts. There appeared to be a league table of who kept most of their premium income. I think he said "we only pay out 40% of income." That was clearly a target. Ticking the nearest description would be an easy one for them to refuse on the grounds of inaccurate description. 1
Gus Potter Posted July 2 Posted July 2 On 30/06/2026 at 09:03, saveasteading said: I wonder, with many insurances being via comparison sites and tick list questionnaires, how often people tick the nearest description to theirs. This could result in a claim being refused. Insurance companies vary with some being fair and others being cynical claim deniers. I overheard a manager of one insurer (it happens that I'm seeing their name all over the place at present) saying proudly that they are by far the "most successful" in avoiding claim payouts. There appeared to be a league table of who kept most of their premium income. I think he said "we only pay out 40% of income." That was clearly a target. Ticking the nearest description would be an easy one for them to refuse on the grounds of inaccurate description. Good observations, none of which I disagree with generally. Your house is often the most valuable asset so take time to read the fine print when the detailed insurance terms and conditions come through. I had one Claim where there was a bit of initial push back, gathering of information and a bit of SE by me reporting on a house on the south coast of England. The gable end of the house was next to the public pavement, lots of prams being pushed and pedestrians walking by, major HSE risk that they clocked once pointed out to them. The thing was so badly built and so expensive and difficult to fix that the warranty provider settled, from memory in about four months after I got involved. The warranty provider bought the house back, paid all costs; professional fees, legal fees, a bit extra for finding another house, removers cost and some ancillary stuff. Some claims can be pretty straight forward and get dealt with relatively quickly. It's not always that bad in terms of reaching a resolution. Some providers are using Claims handling companies.. the clue is in the name.. just how do they make their money? Obviously by making the Claims process as easy as possible and being helpful by not indulging in; gate keeping for example, offer up suggestions to the house holder at what is a stressful time for them .. or some may suggest not?
