puntloos Posted October 25, 2023 Share Posted October 25, 2023 If you take a look at my current roof: I'm sure most of you will agree there's theoretically enough space to the left of the left window. However, I'm told that GSE flashings connect together in such a way that you can't 'stagger' them. Can anyone confirm or deny that one? Does the 'top' panel have to be straight under the bottom panel? And if it is possible, maybe some description I can take to the builder Link to comment Share on other sites More sharing options...
S2D2 Posted October 25, 2023 Share Posted October 25, 2023 No idea but if not, would the same number of panels fit but be centred on the roof? 😬 Link to comment Share on other sites More sharing options...
dpmiller Posted October 26, 2023 Share Posted October 26, 2023 we staggered ours. It meant taking a small slice off the side overlap joint and flashing of the "lower" panel, but the upper one covers it sufficiently and then the flashing roll was slid uo the back of it after tiling 1 Link to comment Share on other sites More sharing options...
LiamJones Posted October 26, 2023 Share Posted October 26, 2023 Have you done anything special with the velux flashings. My list of materials GSE specced for me include MK08 ODL kits, such that the velux and solar can be neatly tied together in a grid layout. but they seem hard to find in the UK Link to comment Share on other sites More sharing options...
puntloos Posted October 27, 2023 Author Share Posted October 27, 2023 On 26/10/2023 at 07:32, dpmiller said: we staggered ours. It meant taking a small slice off the side overlap joint and flashing of the "lower" panel, but the upper one covers it sufficiently and then the flashing roll was slid uo the back of it after tiling Somehow the builder thinks the GSE thinks *have* to 100% click together and I imagine in your case that's not the case? Or is there some 'clicking correctly' happening but you had to somehow trim a few edges? Link to comment Share on other sites More sharing options...
dpmiller Posted October 27, 2023 Share Posted October 27, 2023 yep, it becomes obvious when you have a couple of panels to-hand where issues will occur. Look at my top row in the photo, there's a raised overlap between each panel and the side flashing sits over that again, that's a height of about 10-15mm that you need to squeeze in underneath whatever... Link to comment Share on other sites More sharing options...
puntloos Posted October 30, 2023 Author Share Posted October 30, 2023 The question sounds almost obvious but my solar guy said the GSE is interlocking to ensure watertightness. Sounds sensible by itself but does a roof (the 'top layer' of course) need to be fully watertight? Or do you think you managed to keep watertightness without using GSEs the way they are intended? Link to comment Share on other sites More sharing options...
Alan Ambrose Posted October 30, 2023 Share Posted October 30, 2023 >>> does a roof … need to be fully watertight? Suggest ‘no’ (the membrane is meant to handle the drips, condensation etc) but it’s all a matter of judgement. There’s probably a standard somewhere, but realistically the desired level of water and wind-tightness depend on the house location, orientation etc. That is, if you go off-piste the responsibility is on you (it’s probably on you anyway). Jeez those instructions are hard to read. Link to comment Share on other sites More sharing options...
Tom Adcock Posted June 28, 2024 Share Posted June 28, 2024 On 26/10/2023 at 08:41, LiamJones said: Have you done anything special with the velux flashings. My list of materials GSE specced for me include MK08 ODL kits, such that the velux and solar can be neatly tied together in a grid layout. but they seem hard to find in the UK I'd like to know about this too as I've got solar going in right underneath my velux and I have the standard flashing kit. What did you end up doing in the end? Link to comment Share on other sites More sharing options...
Alan Ambrose Posted June 28, 2024 Share Posted June 28, 2024 I would like to know too. Link to comment Share on other sites More sharing options...
LiamJones Posted June 29, 2024 Share Posted June 29, 2024 They were quite hard to source. I couldn’t find any stock in the UK. I ended up going to midsummer and getting them to order in the side flashings from GSE. For the new v2022 frames and for the MK08 velux I needed the following two parts numbers, per window. ART105512 left ART105498 right i obtained these numbers from technical.support@gseintegration.fr who provided a BOM for my project, attached. Link to comment Share on other sites More sharing options...
LiamJones Posted June 29, 2024 Share Posted June 29, 2024 12 hours ago, Tom Adcock said: I've got solar going in right underneath my velux You may well need the gse mk08 top flashing too, I don’t have a part number for that. also worth mentioning the velux flashing kits are the specific ODL ones. I got the black ones ODL MK08 050001 Link to comment Share on other sites More sharing options...
Dave Jones Posted June 30, 2024 Share Posted June 30, 2024 It could be done but GSE do not make a flashing kit for it so you would need to use lead. The issue is where the top flashing and side flashing would clash, see mine below they clip over the side of the tray and continue over the bottom flashing, in our case lead and the sticky crap looks awful. You would have to go underneath the join and run continuous lead until it meets the bottom flashing ? would be a weak point though. Link to comment Share on other sites More sharing options...
Dave Jones Posted June 30, 2024 Share Posted June 30, 2024 On 26/10/2023 at 07:32, dpmiller said: we staggered ours. It meant taking a small slice off the side overlap joint and flashing of the "lower" panel, but the upper one covers it sufficiently and then the flashing roll was slid uo the back of it after tiling missing all the top and bottom flashings, assumed these were added after ? what are those white lines at the sides of all the panels ? Link to comment Share on other sites More sharing options...
dpmiller Posted June 30, 2024 Share Posted June 30, 2024 2 minutes ago, Dave Jones said: missing all the top and bottom flashings, assumed these were added after ? what are those white lines at the sides of all the panels ? Correct. not white, silver. They're not pure black panels... 1 Link to comment Share on other sites More sharing options...
Tom Adcock Posted June 30, 2024 Share Posted June 30, 2024 On 29/06/2024 at 08:50, LiamJones said: You may well need the gse mk08 top flashing too, I don’t have a part number for that. also worth mentioning the velux flashing kits are the specific ODL ones. I got the black ones ODL MK08 050001 So the standard flashing I have for my velux then are useless? The solar array is going across the bottom of three velux spaced out. Nothing up the sides or along the top of the velux. I’m trying to get the solar as close to the bottom of my velux as possible, do you get what I mean? Link to comment Share on other sites More sharing options...
dpmiller Posted July 1, 2024 Share Posted July 1, 2024 If you try to use the velux lower flexi-flashing alone you'll end up with a gutter behind the PV panel, whereas the GSE top flashing routes the water over the top of the PV. You'd also need to replicate the velux flashing for any areas that *don't* have a velux above them? Link to comment Share on other sites More sharing options...
Tom Adcock Posted July 1, 2024 Share Posted July 1, 2024 Okay I think I’m getting my head around it. So I need to use the top flashing kit for the GSE in roof trays? I thought the water was supposed to run underneath the panels on the trays, that must be where I’m going wrong. I need to get a velux mounted in my roof structure and put a tray up to it and see what room I’ve got. Link to comment Share on other sites More sharing options...
Dave Jones Posted July 10, 2024 Share Posted July 10, 2024 On 01/07/2024 at 10:25, Tom Adcock said: Okay I think I’m getting my head around it. So I need to use the top flashing kit for the GSE in roof trays? I thought the water was supposed to run underneath the panels on the trays, that must be where I’m going wrong. I need to get a velux mounted in my roof structure and put a tray up to it and see what room I’ve got. it does run underneath on the panel below as the trays overlap but the first panel you need somewhere for the tiles to sit on hence the top flashing. You could i suppose do away with it and run lead but would still need a batten to kick up the tiles so would end up with a gap under the tiles. Link to comment Share on other sites More sharing options...
Alan Ambrose Posted July 10, 2024 Share Posted July 10, 2024 Goodness this seems hard to figure out. @LiamJones - you seem to have a neat set-up there. Can ask what the horizontal and vertical repeat distances are please? i.e. the 'grid size'. Also, can I ask what size solar panels you're putting in the v2022 frames? Link to comment Share on other sites More sharing options...
Dave Jones Posted July 10, 2024 Share Posted July 10, 2024 only the height of the panel changes, the trays are in 2 parts so you just increase/decrease the overlap to suit whatever size panel you have. GSE have an app on their website which plans the whole thing for you. 1 Link to comment Share on other sites More sharing options...
Alan Ambrose Posted July 10, 2024 Share Posted July 10, 2024 (edited) Thanks, I remember looking 6m ago and there were many documents with big matrices of numbers. 😒 Oh yeah, I remember... Edited July 10, 2024 by Alan Ambrose Link to comment Share on other sites More sharing options...
Alan Ambrose Posted July 10, 2024 Share Posted July 10, 2024 Unless I am mistaken, it seems to me this is still really hard: (a) choose a PV panel size that is going to be supported into the future (!). Assume these are all fitted portrait orientation as that's the way Veluxes (?) generally go (choose landscape if you insist).To check for max number of PV panels / PV output - check that it fits on your roof envelope fairly sensibly. Something like minimum 30cm margins at roof edges. Use Easy PV maybe. (b) the Velux sizes that seem to be supported right now are MK06/08/10 & PK08/10 i.e. 78Wx118H - 140H - 160H & 94Wx140H - 160H (all in cm). Select a Velux size - probably a smaller size than the panel size you have selected. The max Velux sizes seem to be 160cm high, so with common PV panels, that suggests MK10 or PK10. (c) figure out which GSE frame supports both. Use GSE's app if you like. See if those frames are obtainable in the UK. Otherwise go to (a). (d) that gives you the regular grid size (presumably the GSE frame size). Check that the possible Velux locations are vaguely where the architect intended and move them around to fit the grid. Otherwise go to (a) or (b). (e) figure out the fittings required (maybe the GSE app again) or Easy PV. See whether you can buy those in the UK. If not go back a few steps. (f) all you have to do is buy all the parts and fit them now ... oh you'll need to do something with batten locations. Is that right? Link to comment Share on other sites More sharing options...
puntloos Posted July 10, 2024 Author Share Posted July 10, 2024 1 hour ago, Alan Ambrose said: Is that right? Basically, yes. I would say easyPV was a waste of my time, because you can't get things accurate enough to be both sure you put a "sensible maximum" of panels on your roof as well as not overdimension and suddenly have over-paneled or miscalculated. I did some table/spreadsheet a while ago with the panel sizes and worked out the power, one thing I can say is that 95% of panels in a particular "year" have equal power-per-m2 so the size/form factor doesn't really matter, and therefore more expensive panels do not give you more power. Link to comment Share on other sites More sharing options...
Dave Jones Posted July 11, 2024 Share Posted July 11, 2024 its actually not too bad but needs planning before you put roof on ideally to make any openings work to the panels so it looks planned. Fitting is the easy part, screws and a flashing kit dead simple. Personally wouldn't use anything else but microinverters either for the small added cost. 1 Link to comment Share on other sites More sharing options...
