Gavin’s isoquick foundation on clay soil
gavztheouch
Do not use short fixings. The first 25mm or so is discounted in calculations. After that it is approximately the square of three depth. So you must keep the depth.
The occasional clash with a bar is normal
11 hours ago, gavztheouch said:
Anyone else build timber frame on a structural slab. How did you bolt the frame down?
Our frame was fixed to the slab with 12mm threaded studs bonded into the slab with two part resin.
Did you have rebar where you were drilling? How did you deal with it?
I should mention there is also 16mm glued in threaded rod for the hold down brackets with are Simpson htt4.
There is about 27 of these, some are internal for racking walls.
 How worried should I be about drilling 140 holes in the slab. Any chance it will make a meaning full crack that will radiate much past the hole itself. Not that there is any alternative really.
It is normal. You are right that it might encourage a crack on that line, but it shouldn't if the concrete is good. And it won't matter anyway.
What are the odds of hitting a bar?  With isoquick perhaps quite high but I don't know your details.
The odd rod being cut won't matter either OR the anchor being a tad less deep.   That is an advantage of threaded rod and epoxy...it cuts as required.
But a hit fix will be very much quicker.
There was rebar where the holes were drilled. Used a Bosch concrete rebar cutter drill bit, not used it much though.
19 hours ago, gavztheouch said:
Did you manage to get your slab poured?
Yes. Yesterday. Garage perfect. House just about ok. Not ideal in places.
Awaiting SE reply re anchors still
That’s good. Are you using the concrete as your finished floor surface?
Total cost for the slab was within £100 of £25000.
120 square metres
This was for
isoquick
aggragates
rebar
concrete
labour and pump to pour and finish concrete
does Not include my time and the Sewar pipes and under floor heating
No. Fortunately. We had always planned to finish with resin or micro cement ~3mm layer.
What's your finish?
1 hour ago, saveasteading said:
Have you seen any examples?
I am sceptical that it is a suitable finish.
Yeah our architects house has a concrete floor. I have always liked a concrete floor. My only major concern is staining
Was it a ground (as in with a grinder) finish with the surface removed and stones exposed?
I think you must then seal the surface with a special  varnish to make it look bright and cheerful, and to keep stains from soaking in. Even water will emphasise any microcracks, which are unavoidable. Any random cracking would then  look awful, so it is quite a  skill.
So have I. Very useful for not falling through, even with a forklift. I admit never having tried for a pretty one other than by applying a topping of mineral or epoxy....or tiles.
