Do not use short fixings. The first 25mm or so is discounted in calculations. After that it is approximately the square of three depth. So you must keep the depth.
The occasional clash with a bar is normal
  On 06/08/2024 at 19:29, gavztheouch said:
Anyone else build timber frame on a structural slab. How did you bolt the frame down?
Expand
Our frame was fixed to the slab with 12mm threaded studs bonded into the slab with two part resin.
I should mention there is also 16mm glued in threaded rod for the hold down brackets with are Simpson htt4.
There is about 27 of these, some are internal for racking walls.
 How worried should I be about drilling 140 holes in the slab. Any chance it will make a meaning full crack that will radiate much past the hole itself. Not that there is any alternative really.
Expand
It is normal. You are right that it might encourage a crack on that line, but it shouldn't if the concrete is good. And it won't matter anyway.
What are the odds of hitting a bar?  With isoquick perhaps quite high but I don't know your details.
The odd rod being cut won't matter either OR the anchor being a tad less deep.   That is an advantage of threaded rod and epoxy...it cuts as required.
But a hit fix will be very much quicker.
  On 07/08/2024 at 07:54, gavztheouch said:
Did you have rebar where you were drilling? How did you deal with it?
Expand
There was rebar where the holes were drilled. Used a Bosch concrete rebar cutter drill bit, not used it much though.
  On 07/08/2024 at 15:21, Duncan62 said:
Yes. Yesterday. Garage perfect. House just about ok. Not ideal in places.
Awaiting SE reply re anchors still
Expand
That’s good. Are you using the concrete as your finished floor surface?
Total cost for the slab was within £100 of £25000.
120 square metres
This was for
isoquick
aggragates
rebar
concrete
labour and pump to pour and finish concrete
does Not include my time and the Sewar pipes and under floor heating
  On 08/08/2024 at 11:52, gavztheouch said:
major concern is staining
Expand
Was it a ground (as in with a grinder) finish with the surface removed and stones exposed?
I think you must then seal the surface with a special  varnish to make it look bright and cheerful, and to keep stains from soaking in. Even water will emphasise any microcracks, which are unavoidable. Any random cracking would then  look awful, so it is quite a  skill.
I have always liked a concrete floor
Expand
So have I. Very useful for not falling through, even with a forklift. I admit never having tried for a pretty one other than by applying a topping of mineral or epoxy....or tiles.
