We had some rough ground; made it rougher with a 20 ton excavator moving some of it around / installing a heat pump ground loop etc; and needed to tidy it up.
1) Cultivate / till it (nearest tractor will do)
2) Now what...raking this area by hand requires Olympian endurance...
You will need:
4x 3 metre / 10 foot long 2x4s
3x 1 metre-ish / 3 foot-ish long 2x4s
2x logs as extra weight
2x pipes (for corner marking)
2x ratchet straps (spares useful...)
1x small car
And it works bloody amazing for levelling and compacting *just right* for putting grass back.
The mk1 attempt (6 metre wide rake on a Ford Focus) was a little ambitious. The mk2 attempt (without logs) did fudge all. The mk3 (four logs) was too much of a handbrake. The mk4. you see...just right. I would guess 100-150 kg. Smooths it AND is flat/heavy enough to kick all the field stones and tree roots etc up and out onto the surface. Ready to absolutely not throw in the back of your wife's car like it's a glorified wheelbarrow and spend the journey home wondering how long it'll take to remove all the insects. 😇
Ratchet straps (free end wrapped around the frame once and clamped with a piece of wood; hook end on the car to avoid flying metal bits if it breaks) are the perfect strength for being able to pull this along without being too deadly to car or tree when you get ambitious and chop down to 2 metre width do this bits between the trees...
Next month expect a post about moles. 😂
Edited by markocosic
  • Like 3
That looks great. I tried it with 3 railway sleepers stapped together, dragged along by my mini digger. Didn't do anything like as good a job as yours. I wish i had tried an old 5 bar gate with some weights now.
18 hours ago, Andehh said:
but the dry weather means the ground is very hard.
What are you going to do about all the stones?
Coulds be a problem when it comes to using a rotary lawn mower with those glass doors.
Worry constantly! That was preraking them up, then we put a layer of clean compost type over the top. I'm still finding the occasional one though... Just keep walking and looking for them. :(
I spent hours and hours picking up stones from my plot 😖
When I lived near High Wycombe, the only thing that grew in the garden was flint stones.
Sing along now.
On 07/09/2023 at 20:32, markocosic said:
I usually persuade my wife to get out and open the gate.
  • Haha 2
