tvrulesme Posted August 20, 2023 Posted August 20, 2023 I need to replace some old glass mineral wool insulation in my loft. I have very reduced head height (approx 1.2m) and being a listed building I am not allowed to insulate between the rafters. I have a load of left over foil backed PIR which I was going to stick on eBay. Is there any reason not to use it between the joists on the floor? All searches seem to show PIR between the rafters and rockwool on the floor but I can't find anything which says this would be a bad idea. The loft is very well ventilated and I'll make sure I don't cover any soffit vents etc.
Conor Posted August 20, 2023 Posted August 20, 2023 You'll get condensation on the face of the boards unless you have a vapour control barrier underneath. Last thing you want in an old building. 1
JohnMo Posted August 20, 2023 Posted August 20, 2023 Sell your left over PIR then go to B&Q or Wickes and buy the right stuff.
tvrulesme Posted August 20, 2023 Author Posted August 20, 2023 46 minutes ago, Conor said: You'll get condensation on the face of the boards unless you have a vapour control barrier underneath. Last thing you want in an old building. Thanks Conor. Right you are, hands and knees over the itchy stuff it is.
JohnMo Posted August 20, 2023 Posted August 20, 2023 If don't mind spending a little more b&q do a recycled plastic bottle insulation - not itchy
tvrulesme Posted August 20, 2023 Author Posted August 20, 2023 (edited) 55 minutes ago, JohnMo said: If don't mind spending a little more b&q do a recycled plastic bottle insulation - not itchy Thanks @JohnMo yes I did see that in my local B&Q the other day. Impressive product, I'm sure if you give it a few years there'll be more and more of this. I just can't justify the £10 m2 in comparrison to £2.77 m2 for Knauf Space. I've a whole load of chipboard in the garage so I think I can probably add some boards to crawl on and still come in cheaper Edited August 20, 2023 by tvrulesme
TonyT Posted August 20, 2023 Posted August 20, 2023 I use a site hoover while doing insulation in the loft. Collects air borne particles, saves having to wear a mask and the breathing issues with a mask 1
