To get around difficult( tight) spacing of pipe runs is it common to run pipes under a stud wall for an easier alternate route to any given room?
Thanks in advance for all advice wise ones
It’s probably better to get your studs fixed down first
Edited by nod
I wouldn't put pipes under any wall. Someone will end up putting a nail or screws through a pipe.  Plan it correctly there should be no reason to.
You may get away with if you everything yourself, but if you are getting others to build it for you, good chance of them messing up.
I did this, but dropped the pipes down in to the insualtion then back out again, for added protection. And in flexible conduit.
 Since the first build I’ve become a multi tasker
thanks though
pluming first fix today 💪🏻
Edited by nod
Yeah I had a load of timber over from a job and had two timber 4x2 racking walls across the first floor So I did the lot in a day
