CloGanga Posted July 14, 2023 Posted July 14, 2023 I bought a house with a single wall extension. I intend to transform it into a room and one toilet, not ensuite. A contractor advised me to demolish and build from the beginning. It's that right? I was thinking of building another brick line with insulation in the between. Thanks Clo
markc Posted July 14, 2023 Posted July 14, 2023 You don’t know what the foundations are like and then you need to put in wall ties so probably quicker, cheaper and easier to knock down and start again. if you really don’t want to knock it down then an inner stud wall and insulation
Temp Posted July 14, 2023 Posted July 14, 2023 Perhaps take a look at the websites for insulation manufacturers. Some have guides on how to use their product on a garage conversion (which are frequently single brick).
Mr Punter Posted July 14, 2023 Posted July 14, 2023 You could do as @markc suggests but if this is to be a habitable room you will also need insulation in the floor and the roof, otherwise you will have issues with lack of Building Regulations when you come to sell.
HughF Posted July 18, 2023 Posted July 18, 2023 Step 1, rent digger... Step 2, push it over with digger... Step 3, build it properly...
CloGanga Posted July 18, 2023 Author Posted July 18, 2023 Thanks for all suggestions. I will start looking for cost.
alfaTom Posted July 19, 2023 Posted July 19, 2023 I have a single skin extension on the back of our house that holds the washroom, downstairs WC & boiler room. I have no idea the sort of foundations it sits on but I doubt they would be up to current regs. Luckily the external door & structural wall is still in place from the main building, so we will be knocking the single skin down and rebuilding. I doubt it'd add much to your cost to knock down and rebuild vs the extra labour costs in retrofitting fit wall ties etc.
