MikeSharp01 Posted June 29, 2023 Posted June 29, 2023 We are getting ready to fit the cladding which is formed of fibre cement slates hung vertically. The ones we have have the holes set for the roof pitch but I can get away with a 25mm smaller headlap when using them vertically, and save myself 200+slates! It means adding some new fixing holes 25mm below the ones in the slate. As far as I can see the old holes won't be visible so I am thinking there is no problem doing this but just in case I am being very stupid and cannot see the obvious I though I would seek the collective wisdom! Is it OK to punch new holes and carry on?
TonyT Posted June 29, 2023 Posted June 29, 2023 (edited) I made a cover for my car charger, I just drilled the slate with a masonary bit, on drill not hammer. Never punched a hole in slate and didn’t have spares so drilling worked for me Edited June 29, 2023 by TonyT
Temp Posted June 29, 2023 Posted June 29, 2023 In case not obvious...the lap is determined by the batten spacing as well.
Mr Punter Posted June 29, 2023 Posted June 29, 2023 Why not consider hook fixing? They are much more secure and the slates won't rattle in the wind.
joe90 Posted June 29, 2023 Posted June 29, 2023 1 minute ago, Mr Punter said: Why not consider hook fixing? They are much more secure and the slates won't rattle in the wind. +1, my builder used hooks and a far better method in my opinion (and you can get broken slates out and replace them!).
makie Posted June 29, 2023 Posted June 29, 2023 3 hours ago, joe90 said: +1, my builder used hooks and a far better method in my opinion (and you can get broken slates out and replace them!). Cement fibre slates are nailed then have a copper rivet fitter to stop them lifting. Hooks would be pointless.
Mr Punter Posted June 29, 2023 Posted June 29, 2023 22 minutes ago, makie said: Cement fibre slates are nailed then have a copper rivet fitter to stop them lifting. Hooks would be pointless. Not all. Some can be hook fixed.
