Pocster Posted June 2, 2023 Share Posted June 2, 2023 35 minutes ago, SteamyTea said: Shoot the dog and stop washing cars, it is now illegal to entice a boy scout with your puppy for a bob-a-job Aka “ doing a schofield “ Link to comment Share on other sites More sharing options...
SteamyTea Posted June 2, 2023 Share Posted June 2, 2023 21 minutes ago, pocster said: Aka “ doing a schofield “ I am not full of self pity. I wonder if he is still hiding at his mum's near Newquay. Link to comment Share on other sites More sharing options...
Super_Paulie Posted June 2, 2023 Author Share Posted June 2, 2023 thanks for the info chaps. But like i said, i have an isolator already, the tap is connected directly to the manifold which has isolation at that point. Was just looking for a relatively nice solution so i dont have to go into a cupboard every day to turn it. Padlock and eye bolt is what i am going for. 3 hours ago, SteamyTea said: Shoot the dog and stop washing cars, it is now illegal to entice a boy scout with your puppy for a bob-a-job. I see, cheers. Link to comment Share on other sites More sharing options...
Carrerahill Posted June 2, 2023 Share Posted June 2, 2023 (edited) 17 hours ago, Super_Paulie said: Worried about going on holiday for a fortnight and coming back to a hot tap that's been running for 14 days, sure! The tap is street side, so public facing, although it's a decent area I guess it's not out of the question to occur. Isolate the hot water while on holiday? You could put a 15mm electric valve in, I have that to shutdown my garage supply on the cold feed so I can switch off the water (connection is under the floor so I could not easily add a valve) in the winter. Edited June 2, 2023 by Carrerahill Link to comment Share on other sites More sharing options...
markocosic Posted June 18, 2023 Share Posted June 18, 2023 "Lockable lever taps" (search term) outdoors and a noddy combination code lock? I have these on the cold water outside taps because once upon a time nuisance kids and water meter. 2 Link to comment Share on other sites More sharing options...
joth Posted June 18, 2023 Share Posted June 18, 2023 On 02/06/2023 at 14:23, Carrerahill said: Isolate the hot water while on holiday? You could put a 15mm electric valve in, I have that to shutdown my garage supply on the cold feed so I can switch off the water (connection is under the floor so I could not easily add a valve) in the winter. We have an electronic ball valve stopcock that automatically shuts off when the house alarm is armed. This is mostly to reduce damage if there's a leak when we're out, but also very effectively shuts off all the outdoor taps. I'd never even considered that benefit. (Albeit drawback if we ever have a gardener or automated irrigation, beyond what waterbutts can supply) 1 Link to comment Share on other sites More sharing options...
markocosic Posted June 19, 2023 Share Posted June 19, 2023 12 hours ago, joth said: electronic ball valve stopcock that automatically shuts off when the house alarm is armed Link for more info? Link to comment Share on other sites More sharing options...
PeterW Posted June 19, 2023 Share Posted June 19, 2023 5 hours ago, markocosic said: Link for more info? standard bit of process control kit - the good ones like this only use power when they are in operation so have no hold open / closed power use https://www.solenoid-valve.world/connexion/1-electrically-actuated-ball-valve-9-24vacdc-or-110-240vac-abvm08s 1 Link to comment Share on other sites More sharing options...
joth Posted June 19, 2023 Share Posted June 19, 2023 1 hour ago, PeterW said: standard bit of process control kit - the good ones like this only use power when they are in operation so have no hold open / closed power use https://www.solenoid-valve.world/connexion/1-electrically-actuated-ball-valve-9-24vacdc-or-110-240vac-abvm08s Yes that's what I have. Controlled via Loxone in my case, but with the engineer code I could have the texecom panel directly set/clear an output relay on arm. Link to comment Share on other sites More sharing options...
markocosic Posted June 19, 2023 Share Posted June 19, 2023 10 hours ago, PeterW said: standard bit of process control kit - the good ones like this only use power when they are in operation so have no hold open / closed power use https://www.solenoid-valve.world/connexion/1-electrically-actuated-ball-valve-9-24vacdc-or-110-240vac-abvm08s Thanks! Link to comment Share on other sites More sharing options...
