Nickfromwales Posted July 13 Posted July 13 16 minutes ago, Super_Paulie said: Yeah my shower is pretty much opposite the door as it is. Just wondering if the gypsum based vent as discussed in this thread is more prone to getting damaged from moisture being in such direct contact with steam. Zero chance. 1
-rick- Posted July 14 Posted July 14 14 hours ago, Nickfromwales said: You'd need a better plumber to make this a reality! Not important but I have absolutely no idea what you are getting at here. 🙃
Nickfromwales Posted July 14 Posted July 14 2 hours ago, -rick- said: Not important but I have absolutely no idea what you are getting at here. 🙃 Heat and steam off a decent shower will negate any feeling of cold / draught etc.
-rick- Posted July 14 Posted July 14 17 minutes ago, Nickfromwales said: Heat and steam off a decent shower will negate any feeling of cold / draught etc. Ah. Not sure what a plumber has to do with that. In my mums cold bathroom with relatively weak shower she specifically asked for the fan to be moved further away from the shower head because she thought it promoted cold. Couldn't tell you if it made any difference (used it before and after) but I could see an argument for wanting more steam to hand around (for a short while) in a room like that. (Of course consequences are condensation everywhere but that's another matter).
Super_Paulie Posted 4 hours ago Posted 4 hours ago (edited) Bit of a kick in the balls, when I was screwing up my plaster in grill it cracked a bit of. Not a chance I'm buying another for £70 a go, so what adhesive is best for this to stick the bit back in before I scrim tape and multi over the ceiling? CT1? plasterboard adhesive? 1 step forward, 2 back as per. Edited 4 hours ago by Super_Paulie
Super_Paulie Posted 4 hours ago Posted 4 hours ago 7 minutes ago, JohnMo said: Super glue Like the cyanide based stuff? Might get a tube of Gorilla Glue, seems well thought of.
-rick- Posted 4 hours ago Posted 4 hours ago 1 minute ago, Super_Paulie said: Like the cyanide based stuff? Might get a tube of Gorilla Glue, seems well thought of. cyanoacrylate Loads of brands, your local corner shop will have it, don't think it's gorilla glues thing though. They focus on urethanes and pva I think. I would go for cyanacrylate as its a very thin glue line and fast. Gorilla glue foams and might produce a less nice join.
JohnMo Posted 3 hours ago Posted 3 hours ago 7 minutes ago, -rick- said: cyanoacrylate Couldn't think of the chemical name. Gorilla glue isn't the same. Tiny tube that likes to stick your fingers together.
Super_Paulie Posted 3 hours ago Posted 3 hours ago Probably the same as all the others I'd imagine. 1
-rick- Posted 3 hours ago Posted 3 hours ago Just now, Super_Paulie said: Probably the same as all the others I'd imagine. Indeed!
Nickfromwales Posted 2 hours ago Posted 2 hours ago If you use superglue, do NOT use too much as it won't sand back as quickly as the plaster / paint around it. As it's plaster you could prob happily just use neat PVA, with the benefit of being able to wipe this with a wet cloth to clear away excess when wet. Remember to stop the scrim tape well away from the edge as you defo do not want to catch that when tidying up after the plasterer with some sandpaper; I doubt they'll get them A1 so expect to have some faffing to do before paint. Also, don't forget to take the centres off and remove the foam restrictor before (and put them bloody safe so you don't need to repair those!!).
Super_Paulie Posted 57 minutes ago Posted 57 minutes ago 1 hour ago, Nickfromwales said: If you use superglue, do NOT use too much as it won't sand back as quickly as the plaster / paint around it. As it's plaster you could prob happily just use neat PVA, with the benefit of being able to wipe this with a wet cloth to clear away excess when wet. Remember to stop the scrim tape well away from the edge as you defo do not want to catch that when tidying up after the plasterer with some sandpaper; I doubt they'll get them A1 so expect to have some faffing to do before paint. Also, don't forget to take the centres off and remove the foam restrictor before (and put them bloody safe so you don't need to repair those!!). PVA eh? Any problems with it being above the shower though and reactivating? I guess not once it's been plastered and painted but thought I'd ask.
Nickfromwales Posted 33 minutes ago Posted 33 minutes ago 17 minutes ago, Super_Paulie said: PVA eh? Any problems with it being above the shower though and reactivating? I guess not once it's been plastered and painted but thought I'd ask. You're supposed to paint over these after they've been "finessed" Raw plaster (of Paris) is not meant to be left on show afaik. However, in real life, air will be continuously flowing here 24/7/365, so is it ever actually going to remain 'wet'? A: "No". 1
