jayc89 Posted May 16, 2023 Posted May 16, 2023 Any suggestions? I have 90mm duct going into 125mm plenums. Would prefer a plaster-in/frameless valve in each room, if possible, but the ones I've seen so far are approx £70 each!
Nickfromwales Posted May 16, 2023 Posted May 16, 2023 £70 is a good price. What were you expecting to pay when the petrol service station looking ones are a couple of those 7 tenners or more! Do you have a link to what you’ve seen? I’m spec’ing these for all my projects, the regular ones have never sat well with me, and my clients agree. Plaster in ones ( round and linear ) are just wonderful looking things by comparison. Lemonade job = a couple of tenners. Champagne job = ‘more’
jayc89 Posted May 16, 2023 Author Posted May 16, 2023 2 hours ago, Nickfromwales said: £70 is a good price. What were you expecting to pay when the petrol service station looking ones are a couple of those 7 tenners or more! Do you have a link to what you’ve seen? I’m spec’ing these for all my projects, the regular ones have never sat well with me, and my clients agree. Plaster in ones ( round and linear ) are just wonderful looking things by comparison. Lemonade job = a couple of tenners. Champagne job = ‘more’ I think these were the cheapest I could find - https://www.ventilationland.co.uk/product/46223/frameless-ventilation-valve-round-o-125-mm.html I'd also have a problem fitting them to be fair. They look like they need to be fitted from above (lugs sitting on top of the PB, rather than beneath it like plaster-in downlights), and I have a cold roof with the AVCL running across the bottom of the roof joists, so no access from above...
Nickfromwales Posted May 16, 2023 Posted May 16, 2023 59 minutes ago, jayc89 said: I think these were the cheapest I could find - https://www.ventilationland.co.uk/product/46223/frameless-ventilation-valve-round-o-125-mm.html I'd also have a problem fitting them to be fair. They look like they need to be fitted from above (lugs sitting on top of the PB, rather than beneath it like plaster-in downlights), and I have a cold roof with the AVCL running across the bottom of the roof joists, so no access from above... You slot them in from underneath once the hole is cut, and then you screw up through the plasterboard and into the metal tabs
jayc89 Posted May 16, 2023 Author Posted May 16, 2023 19 minutes ago, Nickfromwales said: You slot them in from underneath once the hole is cut, and then you screw up through the plasterboard and into the metal tabs I only have a 25mm service void between PB and AVCL running across the bottom of the roof joists. The plenum sits above and penetrates through the AVCL, screwed into the joists. I doubt I'll have the wiggle room to slot them in from underneath like that. I did wonder whether I could make an inverse hatch. Screw the valve onto a square of PB 600x600 (to match my service void battens), push that up to engage the plenum, as I should be able to get my hands in to make sure it's snug, then carry on with full lengths of PB again. A bit nasty?
jayc89 Posted May 16, 2023 Author Posted May 16, 2023 1 hour ago, jayc89 said: I think these were the cheapest I could find - https://www.ventilationland.co.uk/product/46223/frameless-ventilation-valve-round-o-125-mm.html I'd also have a problem fitting them to be fair. They look like they need to be fitted from above (lugs sitting on top of the PB, rather than beneath it like plaster-in downlights), and I have a cold roof with the AVCL running across the bottom of the roof joists, so no access from above... Just found 2x for £70 on eBay. The Yorkshireman in me is much happier with that price.
Nickfromwales Posted May 17, 2023 Posted May 17, 2023 13 hours ago, jayc89 said: I only have a 25mm service void between PB and AVCL running across the bottom of the roof joists. The plenum sits above and penetrates through the AVCL, screwed into the joists. I doubt I'll have the wiggle room to slot them in from underneath like that. I did wonder whether I could make an inverse hatch. Screw the valve onto a square of PB 600x600 (to match my service void battens), push that up to engage the plenum, as I should be able to get my hands in to make sure it's snug, then carry on with full lengths of PB again. A bit nasty? A means to an end, is what that option is Carry on, as these are 1000% worth every ounce of your time and effort. ”If it was easy……..” 1
GaryBixhall1984 Posted May 25, 2023 Posted May 25, 2023 I bought these from VentillationLand - the ErgoVent and I love them. Do you have a link to the eBay for 2 for £70?!?! Thanks!
jayc89 Posted May 25, 2023 Author Posted May 25, 2023 4 minutes ago, GaryBixhall1984 said: I bought these from VentillationLand - the ErgoVent and I love them. Do you have a link to the eBay for 2 for £70?!?! Thanks! Well I do, but it's ended, because I bought them
Alan Ambrose Posted November 16, 2025 Posted November 16, 2025 Resurrecting this old thread - has anyone seen plaster-in vents with filters?
Nickfromwales Posted November 16, 2025 Posted November 16, 2025 14 minutes ago, Alan Ambrose said: Resurrecting this old thread - has anyone seen plaster-in vents with filters? Dont you just want to catch this crud at the unit filters, vs climbing up and getting fingerprints on the room vents? Unit filters are cheaper than shoplifting so why add the ballache of having to micro-maintain this?
Alan Ambrose Posted November 16, 2025 Posted November 16, 2025 Well good point - I had a vague thought that it would be good to keep the extract pipes clear of dust.
JohnMo Posted November 16, 2025 Posted November 16, 2025 I use cone filters in the extract terminals, you would be surprised how much stuff they keep out the ducts. 2
Nick Laslett Posted November 16, 2025 Posted November 16, 2025 @Alan Ambrose https://www.paulheatrecovery.co.uk/product/filter-cone-125/ Use on kitchen extract.
Super_Paulie Posted July 13 Posted July 13 Jumping onto this, any problems with fitting one of these Ergovents above my shower enclosure? I like the minimal look compared to the warty ones which are the usual.
Nickfromwales Posted July 13 Posted July 13 40 minutes ago, Super_Paulie said: Jumping onto this, any problems with fitting one of these Ergovents above my shower enclosure? I like the minimal look compared to the warty ones which are the usual. All good, afaic, but most designers will favour it (having the extract location) being placed outside the shower area. No idea why, but in small rooms I guess it’s completely moot.
Super_Paulie Posted July 13 Posted July 13 23 minutes ago, Nickfromwales said: All good, afaic, but most designers will favour it (having the extract location) being placed outside the shower area. No idea why, but in small rooms I guess it’s completely moot. Really, I was under the impression that directly above the source of steam was best.
JohnMo Posted July 13 Posted July 13 Scottish building regs point you to having them at the source of steam either over shower or bath. We have then directly in shower space in two rooms and above the bath in another, but we use the shower in that room most the time. Both layouts work well.
Nickfromwales Posted July 13 Posted July 13 1 hour ago, Super_Paulie said: Really, I was under the impression that directly above the source of steam was best. Apparently not, but I am as bemused as you are. Men in white coats holding clipboards say differently, so who am I to contest...... Disclaimer: I contest EVERYTHING!
Nickfromwales Posted July 13 Posted July 13 35 minutes ago, JohnMo said: Scottish building regs point you to having them at the source of steam either over shower or bath. We have then directly in shower space in two rooms and above the bath in another, but we use the shower in that room most the time. Both layouts work well. I'm a big fan of extracting or supplying as far diagonally opposite the door as is practicable. Airflow across the whole room will (should always) steer my design / execution; not lost a patient yet.
JohnMo Posted July 13 Posted July 13 2 minutes ago, Nickfromwales said: I'm a big fan of extracting or supplying as far diagonally opposite the door as is practicable. Airflow across the whole room will (should always) steer my design / execution; not lost a patient yet. Yep that should be the aim, I suppose by coincidence showers and baths tend to be away from the doorway, so win win 1
Super_Paulie Posted July 13 Posted July 13 Yeah my shower is pretty much opposite the door as it is. Just wondering if the gypsum based vent as discussed in this thread is more prone to getting damaged from moisture being in such direct contact with steam.
-rick- Posted July 13 Posted July 13 4 hours ago, Nickfromwales said: All good, afaic, but most designers will favour it (having the extract location) being placed outside the shower area. No idea why I vaguely remember seeing something about less potential cold drafts when showering if the fan is not directly above.
Nickfromwales Posted July 13 Posted July 13 2 minutes ago, -rick- said: I vaguely remember seeing something about less potential cold drafts when showering if the fan is not directly above. You'd need a better plumber to make this a reality!
