Hi, I was going through my dad's old stuff and found these. It needs a plug, does it have to be a round one to go into a generator or could it be a standard one that we could power via a temporary consumer unit?
We will need to get material up to 1st floor.
Waiting for the equally antique generator to be serviced (villiers engine) and wondered could I put on a standard 13 amp plug on this wonch and test it? The only thing is there are 3 brown wires and one yellow/green. How do I wire it?
Edited by CalvinHobbes
9 minutes ago, CalvinHobbes said:
Waiting for the equally antique genderator to be serviced (villiers engine) and wondered could I put on a standard 13 amp plug on this wonch and test it? The only thing is there are 3 brown wires and one yellow/green. How do I wire it?
Might be a bit less than straightforward. I suspect that it also has a SB3 Magnetic clutch/brake
The rating label shows SB3 and G100 which I think refers to Gear Motor. Can't seem to google up any wiring diagrams.
On 03/05/2023 at 11:00, CalvinHobbes said:
Ah, here it is
That's three phase, hence the 220/380 and the three brown wires issue.
Stick it on a VFD and use that for the controls.
