Yes £2 a month it gives me 3gb which seems to be enough but I have 100 extra gb on the my sky app so I can put more in if needed.
The busier the site the more data presumably will use and its only passing cars for the next 3 weeks.
Edited by CalvinHobbes
I've two of the WiFi models. Be very wary of the connections on the solar panel and the usb in to the camera, I destroyed one because the rubber grommet wasn't tight around the usb port and water got in and corroded the usb port and board. I also had the bracket on the solar panel snap off in a storm.
Hi Conor, would you mind sharing the model numbers of your kit.
Trying to get my head around all this.
Thank you.
Was looking at reolink poe cameras for my place as now have a cat 5 feed to garage and a separate one on front fence.
