Most efficient insulation with UFH?
Philxyz
Could use a phenolic insulation boards like Kingspan Kooltherm K103 Floorboard.  About 10 to 15% better than normal PIR, but quite a bit more expensive. Or normal PIR boards.
Put it down in two layers with staggered joints, all a tight fit. Fill all gaps with expanding foam and tape the top layer. Thin polythene sheet, staple the UFH pipe to insulation through poly sheet and then screed.
OK. Sorry for the delayed response, and thanks very much for the pretty unanimous and clear need to go deeper.
Looks like we can get down to 180mm, will try to go deeper but wont know til on site. Will do the 2 staggered layers, foam, tape and polythene. Will look into the price for a top layer of phenolic.
Thanks everyone!
