Vijay Posted July 22, 2017 Posted July 22, 2017 There was a post a little while ago where someone was asking about digital tape measures. I've got a Bosch digital tape measure which I used for the profile markers, but have been using a steel tape measure for the first course of ICF. For those who've used digital tape measures, how have you found their accuracy? Cheers Vijay
Vijay Posted July 22, 2017 Author Posted July 22, 2017 I remember that post cos it's a nightmare when you have to try and find the laser dot But I almost have the first course of ICF so would hopefully be much easier to locate that illusive dot! lol PeterW mentioned a Lufkin tape measure in the post I mentioned, anyone used them as I'd like to know the width of the actual tape? (I think it's 10mm)
MikeSharp01 Posted July 22, 2017 Posted July 22, 2017 (edited) Over longer distances the digital tape is probably best but aiming is a pain in daylight. A long steel tape for distances over 5m is a must for good setting out and accuracy as plastic tapes are not usually not graduated in MM and can stretch. However all the measuring systems are not super accurate over the longer distances without compensation for temperature, humidity and pressure (depending on system used) EG and 8m steel tape at 20°C will be 8001mm at 28°C so over 40m it will be 5mm out! Edited July 22, 2017 by MikeSharp01 Typo
Vijay Posted July 22, 2017 Author Posted July 22, 2017 Wow, never would have thought that on different days I would have got different measurements depending on weather
RichS Posted July 22, 2017 Posted July 22, 2017 That may be the case, but I very much doubt that any building is actually built to such tight tolerances that it can't take a mill or two difference.
jfb Posted July 22, 2017 Posted July 22, 2017 I've found an open reel tape to be very useful for groundworks/setting out . something like this: http://www.screwfix.com/p/stanley-open-reel-long-tape-measure-60m-200-x-12mm/7775j
Vijay Posted July 23, 2017 Author Posted July 23, 2017 Already got one of those open reel fibreglass ones but looking for something more precise for measurements on the actual build
Triassic Posted July 23, 2017 Posted July 23, 2017 8 minutes ago, Vijay said: Already got one of those open reel fibreglass ones but looking for something more precise for measurements on the actual build I have one of those, I'll have to dig it out and see if it stretches when pulled tight tight as opposed to laying it out on the ground.
Jeremy Harris Posted July 23, 2017 Posted July 23, 2017 2 hours ago, Triassic said: I have one of those, I'll have to dig it out and see if it stretches when pulled tight tight as opposed to laying it out on the ground. It shouldn't. I still have an old metal cased Fibron tape that I used to use for surveying caves, and when I dug it out to use on site it was still fine (if a little bit muddy - full of South Wales mud.........). My old Fibron 30m/100ft tape says that it's accurate to 1/8" inch at 100ft, according to the label on the case, so about 3.2mm. I can live with that level of accuracy for setting out............
