richo106 Posted December 13, 2022 Posted December 13, 2022 Hi All Our project is underway and we will be having a new stairs installed, I was just after some advice as the builders are asking how much of an existing wall needs taking out to make room for the stairs. As my architect plans doesnt show it effects the kitchen area but i think it will I have attached my plans, joist layout and picture of the area to help explain, the floor level with be 250mm higher than currently shown Before people say I should of knocked it down, (maybe i should of) but its the way we decided to go in the end due to cost Any advice/information greatly appreciated regarding the stairs Kind Regards Final - 1050 002i Proposed Floor Plans and Elevations Revi.pdf ACTUAL - X90726G Posi JoistsAll.pdf
Bonner Posted December 13, 2022 Posted December 13, 2022 Number of steps x rise - depth of stringer. About 1m. at a guess. It can be built up or another course knocked off later.
Radian Posted December 13, 2022 Posted December 13, 2022 1 hour ago, richo106 said: I was just after some advice as the builders are asking how much of an existing wall needs taking out to make room for the stairs. As my architect plans doesnt show it effects the kitchen area but i think it will Aren't architects supposed to work this out for you? 1
markc Posted December 13, 2022 Posted December 13, 2022 Impossible to determine unless you know the stair design (depth and angle of stringer) and floor levels. If you have the stair design or drawing then it’s easy to mock up on site
ETC Posted December 13, 2022 Posted December 13, 2022 What’s the FFL to FFL dimension? Whats the rise and going of the steps?
Mr Punter Posted December 13, 2022 Posted December 13, 2022 You will end up with a bulkhead in the kitchen as the stairs will only have risen 1600-1800mm when it clashes with the kitchen wall, so any tall units or wall units in that corner will need to be "modified". Unrelated rant: I hate it when arrows on stair drawings do not indicate up. Just so confusing. It is sometimes even worse when they put "up" and "dn" next to the arrow as they look the same with the plan the other way up.
richo106 Posted December 13, 2022 Author Posted December 13, 2022 Thanks all for the comments and apologies for my very vague/lack of information in my original post. I have now looked a lot more into this and have got some more details. My ceiling height (to bottom of joists) is 2600mm and my finish floor level is 2870mm (2600 + 225 (joists) + 22 (T&G) + 20 (UFH & screed) I wanted to start the stairs at least 400mm away from the snug/study door way and then relating back to my joist layout this gives me a total horizontal length of roughly 3140mm I had a little play on stairbox and this fits within regs OK. 42 degrees is the max allowable pitch of the stairs, does this feel steep? There is different options regarding number of steps so alters height per step and also going (depth of step) Can anybody with a bit more experience offer any advice on a 'nice' stairs pitch, step height/depth That is my plan @Mr Punter tall kitchen units along that side to hide the stairs bulkhead My plan now is to get the posi joists installed when the building is ready, then string a line down at the correct angle to show what bricks need removing? Thanks again
Mr Punter Posted December 13, 2022 Posted December 13, 2022 If you have gone for posi joists for MVHR ducting, make sure the ducting goes in with the joists and you don't get stuffed up by strongbacks or end walls, especially if you are using rigid duct.
