WWilts Posted November 28, 2022 Posted November 28, 2022 (edited) New build in progress. Moisture between panes condensing on outer pane. Defect or just normal? Edited November 28, 2022 by WWilts
craig Posted November 28, 2022 Posted November 28, 2022 If between glass panes, glass unit has failed. Replacement glass unit required. 1
WWilts Posted November 28, 2022 Author Posted November 28, 2022 Need to check if it is really between panes or just on the external surface of outer pane
craig Posted November 28, 2022 Posted November 28, 2022 (edited) 21 minutes ago, WWilts said: Need to check if it is really between panes or just on the external surface of outer pane If it is external, it’s doing the job it’s supposed to. Edited November 28, 2022 by craig 1
Bonner Posted November 29, 2022 Posted November 29, 2022 6 hours ago, craig said: If it is external, it’s doing the job it’s supposed to. It’s fairly obvious where the condensation is formed, just wipe it. If it doesn’t come off, on the inside. My windows (unoccupied new build) have loads of condensation on the outside every morning, presume this will go when it is heated? 1
ProDave Posted November 29, 2022 Posted November 29, 2022 The links to the pictures don't work for me.
Gone West Posted November 29, 2022 Posted November 29, 2022 2 hours ago, Bonner said: My windows (unoccupied new build) have loads of condensation on the outside every morning, presume this will go when it is heated? I would hope not. Mine only cleared when the sun came up or the wind started to blow. If it clears when the house is heated, the glazing isn't keeping the heat in enough. 1
ProDave Posted November 29, 2022 Posted November 29, 2022 5 minutes ago, Gone West said: I would hope not. Mine only cleared when the sun came up or the wind started to blow. If it clears when the house is heated, the glazing isn't keeping the heat in enough. Our north facing windows have almost permanent condensation on the outside at this time of year. Indeed it's ice on the outside of them at the moment. As above it shows they are working and not letting enough heat through to melt that ice. 1
