Digger1 Posted November 26, 2022 Posted November 26, 2022 I have a 300m2 property to spray from mist coat to final finish. Recommend me a paint sprayer please. Budget £1500. Thank you!
Ferdinand Posted November 26, 2022 Posted November 26, 2022 I shouldn't think you will need to spend £1500, even for a new one.  But I am not *that* up to date. I assume you are talking airless.  Mine is a Wagner one which comes on a trolley with a 15m hose.  It has happily done more than one house and a 700 sqm gym in an industrial unit, which was of the order of half that price new.  But I am going back 4 or 5 years.  F
Digger1 Posted November 26, 2022 Author Posted November 26, 2022 Budget is upto £1500.  Happy to hear recommendations under this price.   With my limited research i assume i want airless, and a long hose is a must.
Buzz Posted November 26, 2022 Posted November 26, 2022 I used one of these https://www.screwfix.com/p/wagner-control-150m-300w-electric-high-efficiency-airless-paint-sprayer-230v/400gt £350 , hose is 7.5m long . Couldn't fault it .
Radian Posted November 26, 2022 Posted November 26, 2022 20 minutes ago, Buzz said: I used one of these  Did you take to it straight away or find yourself 'learning' how thin to make the paint and how far away/fast to spray it? I ask because I nearly returned a Wagner airless sprayer - but persisted and eventually got the knack. Maybe because I was used to conventional compressor spray paint kit. Anyway, once I got the hang of it then yes, a great bit of kit.
Kelvin Posted November 26, 2022 Posted November 26, 2022 It takes practice for sure. One advantage of a self-build is you have plenty of walls to practice on. 😂 Mine is also a Wagner and highly recommended. I bought mine second hand.Â
nod Posted November 26, 2022 Posted November 26, 2022 I hired a Wagner Absolutely brilliant Wagner is the only make I see on siteÂ
Buzz Posted November 26, 2022 Posted November 26, 2022 6 minutes ago, Radian said: Did you take to it straight away Thankfully a mate who once was a painter gave me a few pointers, for the mist coat use contract trade emulsion, get a 10l tub put 5l into another tub and add 1l of water into each and mix well, top coats worked best with the same thickness as the mist coat but the amount of water needed varied depending on the paint. Learning how to spray was definitely trial and error 🙃 Â
Temp Posted November 27, 2022 Posted November 27, 2022 I would only use a washable emulsion for top coat if I was building again.  Nothing but Zinsser in bathrooms. Â
