4 minutes ago, ProDave said:
That would not even meet building regs in Scotland.  The "activity space" required is bigger than your entire room.
Yeah I know the regs for a ground level wc are for wheel chair access etc . But I’m below ground 😁
Kind of like a toilet on a plane .
Photo shows it all .
I’ll just remove the WC before bco inspects 😂
It might do as a urinal stall......
Alternatively put the bowl on the back wall and don't bother with the door. Just hope you don't live with anyone of delicate sensibilities.
  • Haha 2
Well that’s the thing . This is a SWMBO request . If I needed a 💩 in there not only is there not enough space but I can’t squat low enough . I’ll tell bco “ super efficient use of space maximising essential amenities “ - sounds like council BS they like .
SWMBO also not sure about the doors … only 45cm wide 😁 . Couldn’t fit 2 60cm next to each other and architrave . Though a wider door on the WC doesn’t really help .
Are you planning on fitting a stool in there?
I should have posted this one earlier.  How to avoid the saniflow?  Raise the WC to match the drain invert level
  • Haha 4
Not sure BCO would like that!
Edited by pocster
39 minutes ago, Ferdinand said:
You should perhaps have used a corner loo and a corner whb for that.
Needs to be a macerator though
Thanks for that. A scene that's going to feature in my nightmares from now on. 🙄
Just needs a hand rail 👍
