Brick and inner skin block or brick and inner skin Timber frame
Aks
Hi I was looking for advise for our new build we have been advised by our architect to go with brick outer skin and timber frame inner skin but with new SIP tool we have been given Actis insulation which we have to do insulation by 3 layers ans we are Not sure which is cheaper and strong brick and block or brick and TF. Please advise.
It’s all down to personal choice
Brick and block has always been cheaper than TF
More so now Due to timber prices more than doubling
Brick and block have been largely unaffected
Though facing bricks can be in short supply Due to major house builders pre ordering 100s of thousands
3 minutes ago, Aks said:
Could I know how
much does it costed you per square meter and where ch year it was.
It was part of a house build as well so no cost just fir the workshop I am afraid, plus it was 4 years ago and costs have risen since then.
Thanks Nod. So there is no
advantage in choosing
inner leaf in TF than block. As you said TF is
expensive than Bock. Now as
per every one comments I can know that TF going to cost but more thank traditional one. But i was looking to know how much difference it will be around.
There’s a massive advantage to TF
You will. Be watertight in a couple of weeks and able to start the inside while the brickwork is going up on the outside
But this comes at a price
I'd go masonry every time. I have done TF and I am very happy with it, but I just prefer the robustness of block/brick builds.
I have just finished the shell of a garden office for my parents and its block/thermalite with 50mm PIR in a 100mm cavity. From foundations to wall plate it went up faster and cheaper as a single piece of work rather than building the TF, wrapping it, insulating between the studs etc.
The masonry approach has also had many benefits through the build too such as penetrations, you just core what you need when your ready, on my TF I had to pretty much know the layout of things at a really early stage to get vent duct and pipework in and through the TF neatly and sealed up properly. It has also saved us heaps of ply as I will not need to ply the walls out before the plasterboard where wall hung cabinets etc. are going.
Things it will slow down a little will be electrical install, but in a shell of a building I will just chase and cap where needed and I think it will still be easier than fishing cables through 100's of studs!
On a bigger build, i.e. whole house, TF does have the speed to watertight benefit, but this is a benefit we often mention, but one that only impacts a small period of the buildings life. Almost as if TF is built for the benefit of the builder and then the rest of its life it's not as good as it maybe could be... just thinking aloud here, not knocking TF as I have it, but I know what I would do next time round.
Edited by Carrerahill
I work on both TF and solids
We went with solid the first time round But looked at TF for this one
before timber prices rocketed But found it difficult to justify the extra cost Probably more so now
In saying that Without TF I don’t think there would be anywhere near the amount of self builders
